fuel pump spacer
Results 1 to 8 of 8
fuel pump spacer
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default fuel pump spacer
    Ok I bought a new fuel pump for my 460 directions say to use old spacer from old pump but when I took off old f. pump there was no spacer should I buy a spacer and put it on or is it ok without it.
    Sep 2008
    OC, CA
    Not sure what you mean by spacer. If you mean gasket, yes you should use one if you don't want oil leaking out. Buy one, make one or at least use RTV gasket maker.
    Aug 2011
    indy.
    No I have the gaskets. I guess its used to properly mount the fuel pump to get the correct stroke off the camshaft
    Member Romper Stomper's Avatar
    Dec 2011
    Just compare the pumps. If the pump arms look the same and are the same length (which they should be if you just got a replacement pump) then you shouldn't need a spacer. Also, im not sure if those ride directly on the cam or if they have a pushrod, but if there is a rod, putting a small dab of silicone on it will save you a lot of time and headaches...IMO
    Quote Originally Posted by Romper Stomper View Post
    Sillicone???...you mean grease?
    Dec 2011
    Oops.... Yeah, I meant grease. I was thinking about silicone to seal it....
    Chevy will have a push rod...ford will have a longer tongue that runs on the cam.
    Made In The Shade
    Custom Window Tinting
    Aug 2011
    indy.
    So I assume I'm ok without the spacer then.. thanks
