Loader Bolts
Results 1 to 14 of 26
Loader Bolts
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default Loader Bolts
    So I figured how would be a good time to pull the loader, check and replace bolts etc.
    It had the short bolts in it, which I will replace with longer bolts, so I can put the insurance nuts on the inside.
    I couldnt get them broke loose, broke an allen off by hand in the first one, in the left one I twisted the allen with a my impact, I was going very slow and could see it twisting. After a few choice words I got the heat out. I will be drilling out one bolt. But got the rest out...finally.
    These can be a bitch, specially laying on your back with limited room to work We "overdrill" & tap to 5/16 NC and use Grade 8's thru the top of the casting and nylocks , also should be checked/inspected regularly , on another note , for those with broken bolts which result in "oversize holes we also recently employed some very cool inserts for a little differerent set up Tom
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    I did the same thing with mine, the stainless bolts were just gaulled in the threads. I shit canned those and am going down to the Rule co. and getting some grade 8's. I ended up whacking them with a hammmer and cussing and using PB blaster and cussing some more but they came out.
    I had to drill all 4 of mine out and retap to next size up.
    Made In The Shade
    Custom Window Tinting
    Senior Member bc18's Avatar
    Haven't taken mine out yet
    Senior Member DonnyLe's Avatar
    Sep 2009
    Livermore, Ca
    Actually we had better luck with flat heads instead if allen's. I used to put a floor jack under the screwdriver and jack pressure up on the screwdriver then just turned it with a open end wrench. If you run a Firebird or in salt water anywhere if is a good idea to pull off all your hardware when you are finished. Pulling off hardware after running at places like that if you let it sit is a tree you do not want to climb!
    Quote Originally Posted by DonnyLe View Post
    Thats a great idea..
    Apr 2011
    Tulsa,OK.
    Impact driver and big hammer.
    Led
    Led is offline
    Jul 2010
    I did not think that slotted head bolts are race legal? I am not racing this boat, so I will definitely use what I have.
    Senior Member slow67's Avatar
    DFW
    You also could weld a nut to the head of the bolt (let it cool back down before trying to remove it).
    Anza Valley, Lost Lake, CA
    I have taken a cold chisel, place it on the head of the bolt and hit it with a hammer a few times. Has worked for me. Is best to change them out every season.
    Anaheim Hills
    I had to do that on the rear of the intake when removing the ride plate. One of the bolts seized and snapped the head.
    Not to thread jack but I have a question:
    My intake was drilled way to big for the bolts. So there is a lot of play and the intake comes loose all the time and I have to tighten it. Is there and easy fix to this? Bigger bolts don't seem to be an option. The holes are about 7/16". I had no idea until me and Dave Ebbert were replacing the bolts and saw how huge the holes are. It looks like someone drilled out previous bolts and used way too big of a bit.
    Bullhead City, AZ
    I run 3/8" loader bolts in my Comp Jet ! They are also through bolted, for safety !
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Quote Originally Posted by NiceGuyEddie View Post
    Whats the size of the hole thats "too large" ?
