jet lingo.
Results 1 to 14 of 22
jet lingo.
    Jul 2009
    Hesperia California
    Question jet lingo.
    Ok, I'm still a newbe when it comes to jets. What is a loader, and a ride plate and what do thay do for the jet boats. I'm sure the answer is well over my budget and horsepower range.
    Maple Ridge B.C. Canada
    a loader is a part that replaces a grate, if you have one ,that bolts on inside the jet intake to direct water into the impeller better. if you have one,search "check your loader" here on pB. a ride plate is a plate that goes in from the intake under the jet output,helps with "ride" and lift. the intake needs to be removed to install the "big job"
    Redding, CA
    The "plate" under the jet unit is a "ride plate".
    It bolts to the rear of the intake under the boat (Intake has to be machined to accept it), and also bolts to the pump as you can see.
    Usually is installed with a "shoe", which is a "scoop" at the back of the intake under the boat to force water into the intake when in motion.
    Fancy ones are adjustable as far as angles.
    A loader replaces the rock grate under the boat at the intake. It actually installs up inside the intake from the bottom and has "fins" that also direct water up into the pump while in motion.
    Here is a pic where you can see the back of the ride plate. (Mine is NOT a fancy one!!)
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    Member lenker's Avatar
    Costa Mesa
    I remember chating with you about your boat a couple months back. I believe I have the same boat. 1996 ultra formula. Not sure what year yours is or what setup is in it, but when I got mine it had ride plate, shoe and loader in it already. The pump is also set back pretty far, witch I believe they did to make more room for the back seat. also from what I hear its a southwind bottom. Ive been in the process of tuning and building new hardware the last couple of weeks cause it was all pretty tired and worn out. the loader and ride plate both had cracks in them. I would be interested to hear more about your boat and its setup. or if any one elses out there has some more info on these boats thanks.
    Brett Lenk
    Missinglenkmotorsports.com
    Jul 2009
    Hesperia California
    My ultra is a 97, and it doesent have any of that stuff, I beleive that someone swaped out the engine before they traded it in to the dealer I got it from. I have a stock gen.V 454 (truck engine) I rebuilt a couple years ago, with a edelbrock performer intake and a edelbrock 850 carb, 12c dominator pump, stock. runs great. not really that fast. top is about 55-60 @ 4350 rpm. seems to be a heavy boat compared to some of the boats my friends have.
    Thanks for the input, now I have some idea what some of these treads are talking about.
    Costa Mesa
    right on. Im no expert on any of this but with doing all that stuff it will help free the boat up and you will get more MPH. Also doing work to the impeller and possiblly and inducer will help alot with getting max RPM and get that heavier boat out of the hole harder. its kinda fun playing with all the setup also. I would recommend tunning on it if possible
    Brett Lenk
    Quote Originally Posted by lenker View Post
    if you have cracks in your loader ,you better fix it before you go out again!
    Costa Mesa
    Quote Originally Posted by rogerroost View Post
    10-4 on that im building a newone out of 3/16 chromolly. ive read in some of the other threads that it can be a pretty scary deal when they let go
    Brett Lenk
    ya! pullin mine today to get magnaflux. i do it every winter ,just makes me feel better
    gets 'em wet ultrajet's Avatar
    folsom, ca
    Quote Originally Posted by jet pilot View Post
    Hey JP. My 2000 ultra formula has similar engine MP454 with the a little bit of upgrade(390hp), dominator pump(set way back) w/ droop snoot, tapered shoe and rideplate. It does about 70mph(5100rpm) when the water is good. I tinkered with a loader in it a couple of summers ago. I really got zero benefit from it(HP probably too low, I guess). I really felt like the boat didn't handle well with it and everytime I took it off after adjustments and put the grate back on I felt the boat was faster and handled better. For what it's worth I had the biting edges of the loader about even with keel at the time. The rock grate I have is the "speed grate" that AT offers. If you don't have a droop I would try that first for a little extra speed. Mine noticeably ran a little drier with the droop.
    Costa Mesa
    Quote Originally Posted by ultrajet View Post
    Tapperd shoe huh? did you ever try any backcut stuff? I got mine with a flat shoe and im gonna put a backcut shoe in it to try and free the boat up.
    Brett Lenk
    folsom, ca
    Never messed around with the shoe although I have at times thought about switching to a back-cut. With my fairly stock engine I just don't think it will make much difference. To get more speed adding hp would be the ticket at this point.
    Sep 2011
    Ventura County, CA
    Since this is a newbie "lingo" thread, maybe some of you veterans can tell us what the difference is between a flat, tapered and backcut shoe.
    How about "wedge plates", and when are they used?
    Michael
