Intake Fins?
Results 1 to 14 of 17
Intake Fins?
    Okmulgee Okla.
    Default Intake Fins?
    My sons 17ft winger gets a little loose in the ass when it's up and running. There are no fins on the intake to help keep it from wanting to wonder around or slipping in a turn. This pump does have a ride plate. Question I have is how would you cure this problem short of swaping intakes. Also no rudder, but they don't work worth a s#!t anyway. any suggestions.
    Poster at the request of the U 17 comander. LOL
    well the block is GM any ways
    IS UNDER FIRE
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Wild Hair View Post
    I wonder if mounting some home made fins to the sides of the ride plate would work ??
    Aug 2009
    Fox Valley Wisconsin
    Have asked this ques. before. I think your idea of fins on the rideplate sounds like it may work. Easy fix if it does. I think I'll try it this summer.
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Buy a stainless steel turning fin from REX, mill a slot in the center of your ride plate and bolt it in, did that on mine worked great.
    Ron
    One less DEALER means more DISCOUNT for you
    I have a small keel in front of my intake...bout 4-5". Its a bolt on thru hull.
    Made In The Shade
    Custom Window Tinting
    Okmulgee Okla.
    Some good ideas here. I'll throw them at him and see where it goes. I kinda like the stainless fin in the middle of the ride plate. Now if he don't beach it that should do the trick.
    Thanks guys
    IS UNDER FIRE
    Quote Originally Posted by ATM View Post
    Ron
    Any one have a pic of this turning fin you all speak of?
    Oct 2010
    Lake Dallas TX
    yeah I'd like to see it as well ... my "F" pump doesn't have fins either and it's REAL loose in a little chop ... sticks fine if the water is flat tho' ....
    Don personally I'd pull the motor and snake a "new"intake into is (or repair the fins ) lots of support here , some grunt work but actually a pretty simple job , got complete photo deal on this if you and the kid want to take the plunge Tom
    Aug 2009
    Do any "F" pump intakes have fins? Also I think that I may use a alum or SS "C" channel inverted for a ride plate. Then It would be like it had 2 smaller fins.
    Quote Originally Posted by BAJA JA View Post
    Have actually seen this done (past photos) as well as considered it to combat that "a$$ end on butter" feeling some boats expirience but never gone there , On Panther ride plates for example we sometimes fabricate two fairly deep fins (one on either side of the rideplate) Honestly not certain how one would go about attachment to an "E" or "F" intake area succesfully and safely , hardware changes like that can create handling issues as well ... Tom
    Aug 2009
    Thinking of just replacing the flat metal ride plate with a "C" channel.
    Okmulgee Okla.
    I tried to talk him into that before I started this thread. I have set an intake before. My first jet was a trade in hull and totaly striped of metal. Bought a new Dominator G pump with intake, transom cover,throttle, sterring and shift cables, and PTO for $1600 from Evin Capps, he showed me how to set it up and epoxy it in. I ran that boat for 9 years with no issues with a SBC, Oh he also threw in a used set of small block headers. Try loading the parts bin with all that for $1600 now. I've been hooked every sense.
    IS UNDER FIRE
    Interesting concept , curious to see it Tom
    this is an example of the Panther with extended fins
