[Question] impeller good bad A or AA Pics....
Results 1 to 14 of 34
    77 sleek. corbin5754's Avatar
    Aug 2011
    indy.
    Default impeller good bad A or AA Pics....
    I don't know if you can tell from pics but if you can is this impeller in ok condtion couple of the blades are a little beat up but not horribly. And is it a or AA impeller its on a Berkeley E pump sleekcraft executive.
ID:	149690   Click image for larger version.
ID:	149691   Click image for larger version.
    Can't tell from looking at it from there
    You have to pull the bowl to tell
    What size/pitch
    Looks like it has ate a few rocks
    Sent from my iPhone
    #55
    Outlaw is correct , its not possible to accurately ascertain what your impeller is (AA, A etc) from a front view or its general condition (except for the obvious), It does however look like it may be a stainless and irrespective of what cut it could likley use some "detail work" call if we can help you ! Tom
    B1 Racing cs19's Avatar
    IMO that impeller is pretty hammered, Id be cleaning that up if it were mine.
    B1Racing.net
    Bullhead City, AZ
    X2
    IMO - That thing is in need of some serious help, may require some welding to square up the leading edge. Being the front is that bad I bet the rear/trailing edge is real bad.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Jan 2012
    Default impellor
    you mentioned it was a berkley e pump aa impellor is 9.25 diameter berkley bowl is only 9. unless the bowl has been modified it probably is not aa
    Quote Originally Posted by bradyte083 View Post
    With due respect brady you may want to review your facts (above) re Impeller "sizes" and "cuts" particularly respective to Berkeley applications in general Tom
    Bullhead City, AZ
    Berk 9" impellers will go all the way up to A4
    Jim & Amanda Rich
    CJ 72 & 53c
    Aug 2011
    indy.
    What all has to be takin off to get to the impeller ill probably just take it off and have it fixed from the jagged edges on the blades.
    Quote Originally Posted by corbin5754 View Post
    With an "E" model jet pump , you simply need to remove the steering nozzle , bowl and Impeller nut , then pull the impeller for inspection and /or repair Tom
    Aug 2011
    indy.
    Thanks you guys are awesome.
    Aug 2011
    indy.
    Is there anything I should replace besides the bowl gasket while I have it all apart.
    Bullhead City, AZ
    Check shaft movement, up and down then in and out !
    Jim & Amanda Rich
    CJ 72 & 53c
    Feb 2012
    Default put the performance in in that tri hull for sale.
    Quote Originally Posted by Squirtin Thunder View Post
    X2
    thats a front line seller for you blunder, looks like the one that came out of that u boat you left some years ago. weld er up and go racin. just sayin.
