21' Open Bow Performance Mods
Results 1 to 5 of 5
    Sep 2008
    Yuma, Az
    Default 21' Open Bow Performance Mods
    So I'm kicking around the idea of adding a new 750cfm carb, intake and ignition system on my 21' open bow Ultimate. Aside from knowing its heavy and definately not a performance hull; I'd like to know if anything will be gained by doing those add on's. I won't be cutting down the impeller or adding an inducer. I'm sure someone here has done it and like to know if it gained a few MPH. Aside from breathing better and better response, anything else to gain? Its either buying the carb and adding a few extra speakers. Thanks in advance.
    boatless....
    Dec 2009
    Northern Indiana
    Would be good to know your existing setup before can make any comments on results of any upgrades.
    Sep 2008
    Yuma, Az
    Quote Originally Posted by fastmarlene View Post
    I have a bone stone sportpac marine power 454 bbc. Dominator pump with A impeller. Droop and ride plate. Thanks
    boatless....
    corona calif
    Default 21 Ultimate
    Quote Originally Posted by YumaJet View Post
    The mods you have proposed are going to enhance the quickness and wil give you a slight gain in mph. Iwant you to check the right side bottom and see if there is a substancial hook on the bottom of the boat.It has been my experience
    this boat has a lot of hook in the bottom especially on the right side.
    Sep 2008
    Yuma, Az
    thanks for expert opinion. i know its hard to say how much mph i would gain, but im shooting for 5-10mph with alittle extra fine tuning on the stock motor. aside from the bottom being uneven, i didnt see much of a hook. the flat keel doesn't help with much either im sure.
    boatless....
