Bowl detail work
Results 1 to 14 of 27
Bowl detail work
    Senior Member Amango's Avatar
    Sep 2009
    Default Bowl detail work
    Is it worth it to do bowl work. Say you have a 95 mph 18 foot bahner with a stock american turbine bowl no work done to it. What kind of gains can one expect? and what should a nice detail job run price wise?
    Thanks in advance
    Coeur d'Alene, Idaho
    Quote Originally Posted by Amango View Post
    Thanks in advance
    Are you sure you have a boat with a stock pump that is doing 95 mph..Did you gps that speed?
    Sep 2009
    Yep GPS. I built the pump. Stock bowl ss impeller loader etc but stock bowl.
    Senior Member lupo1904's Avatar
    Feb 2011
    how much hp? was the gps upside down?
    Just Curious, is it an AT bowl or Dominator ?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Why are you guys so surprised a stock bowl can run 95 MPH? Especially with so few details about the boat/engine combo.
    Atlanta TX
    I'd like to hear the "Answer" too.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    everyone knows a bowl detail is good for at least 30 mph duh thats how you get a 70 mph boat to run 100
    Feb 2011
    well i have a 79 tx-19 with a 468 and a berkley pump droop, rideplate and i know its not the lightest lay up but probly 400 pounds bare hull and i had a aluminum A impeller but its getting a make over as we speak full race pump with a bronze B.with the old shit in the pump i would hot 86mph at 6200 rpm. just sayin and i put a 250 shot to it and gps at 105 at 6700 rpm but people that saw me on the juice said it didnt look like 105mph
    San Clemente, Ca
    lupo1904, 6200 RPM with an A impeller and only 86 MPH? Something doesn't sound right. My previous mill put down around 500ish HP, my pump was way up in the boat (i set it back 5.5" and the hand hole is only half out so that tells you how far this thing was in the boat), I had the standard MPD loader, droop, and PD, no shoe, no ride plate. My impeller was an old aluminum A with one of those HTP Ultimate Wear Rings and we all know how those don't work . My boat ran 86 MPH on GPS multiple times and 84-85 MPH consistently. Also my bowl is an old JC (no split bowl) that was converted to a split bowl. The inside of my bowl (still to this day) looks like i run rocks through it daily for fun. This last season i tried to clean it up a bit but really all i did was clean up the veins edge.
    My engine now makes close to 700HP, my impeller is now a stainless AT A (when measured it was closer to an A+) and I can still only spin it to 5400/5500 RPM. Boat has seen the low 90's MPH wise and there's some left in it.
    Feb 2011
    Thats what i got bud, my impeller was pretty chewed up and my pump really needed a rebuild its now getting a aggressor bronze B and bowl work a stuffer and inducer should spin less rpm and gain a little mph
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by HBInHeat View Post
    Yes i agree
    Senior Member zacho!'s Avatar
    tucson, Arizona
    Quote Originally Posted by lupo1904 View Post
    86/62/a? Weird
    San Clemente, Ca
    Well that was my point, a stock pump that's setup correctly can perform well. You don't have to have detailed this and detailed that. I am curious though what kind of gains one would see out of a detailed bowl. My guess would be alittle more bite and pull less rpm
