Pop off seat belt
Results 1 to 14 of 17
Pop off seat belt
    Dec 2010
    Sapulpa ok
    Default Pop off seat belt
    This is just an idea what u guyz think ?? The fitting is ss for strenght. The straps are rated @ 1450 lb. EA Just need to take em in to the strap shop & get them sewn up I should have around $40.00 in them total they will also be sewn around the ss camp near the top of the discharge.
Name:	pop off pics 006.jpg
ID:	150515Click image for larger version.
Name:	pop off pics 003.jpg
ID:	150516Click image for larger version.
Name:	pop off pics 004.jpg
    Okmulgee Okla.
    I like it patten it and I'll split the profits with you.
    Pump looks good. And so does the OHBA member sticker That sticker alone should be worth 3 tenths.
    well the block is GM any ways
    IS UNDER FIRE
    "Find a need and fill it" NICE job !
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by Wild Hair View Post
    I dam sure hope sooo 3 on the sticker 2 or 3 in the setup. I wish it was that easy !!!
    San Diego, CA
    While the idea is good. It's already been done with a much thicker strap. Do a quick load calc on the three bolts that hold down the valve. 3.14 x Radius(squared) = the area of the bolt. Say the bolt you are using are the good 450SS bolts that have a Tensile strength of 180,000 PSI. You quickly understand the 1450lbs tensile strength of straps is peanuts in comparison to the strength of the bolts already there. The bosses in the cast housing are weak points too not to mention. The berkeley's are thinner and tend to be the ones that break most of the time, not to mention the ears are weak points in the casting launching the valve into the lake. The clamp over the top of the valve seems to be the best option for guys who don't want to risk it. The shock load is what seems to blow the valves off the boat and the -08 AN line that guys are using on the air dump usually gets snapped too. I think a couple of guys have blown a valve off and had it saved by the AN line but not the norm.
    Boat 405.
    Dec 2010
    Sapulpa ok
    I'm just trying to secure it in the event it comes off. Not trying to use the straps for clamping force. Just don't loose it in the drink.Chris said that they haven't lost one with this clamp system YET
    CANT RE MEMBER FARMER JOHN's Avatar
    Sep 2008
    DOME VALLEY,AZ
    Kinda like this ?
    Senior Member Futs's Avatar
    Orange CA, Big River
    Sweet tool bench. Wish i had a work area on my boat to throw the loose tools on.....
    I have an extra snap on tool cart i could sell you cheap.
    Dec 2010
    Sapulpa ok
    Quote Originally Posted by FARMER JOHN View Post
    Kinda like this ?
    Yep Shit I would've bought that. Hell 40 bucks and some time. I think it'll keep it off the bottom that's what I'm after. This things a pig compared to the fast guyz. Our goal is 5.80 1000' It may take 40# of boost to get there just want to do it once. Been 6.004 105-107 deg 5500 da 70% hum 25 psi I think it's doable.
    Dec 2010
    Sapulpa ok
    I have 2 carts full of $hit. I just lay a towel down & start stackin beer cans & tools when I can't find stuff I stop and clean up & make another mess & repeat it's a vicious cycle
    Sep 2008
    DOME VALLEY,AZ
    Quote Originally Posted by piston in the wind View Post
    You have the right idea, to keep it from going to the bottom, or worst yet, stay on the line and beat the crap out of the back of your boat.
    Looks good!!
    Sep 2008
    DOME VALLEY,AZ
    You need to pick up one of those work covers the the Doctor is making, they really save the paint or gel
    Senior Member Suck My Deck's Avatar
    Oct 2010
    yuma
    ur up late for a farmer
    Sep 2008
    DOME VALLEY,AZ
    Quote Originally Posted by Suck My Deck View Post
    A little early for drunk posting
