bowl question
Results 1 to 12 of 12
bowl question
    Broke Member monstertahiti78's Avatar
    Feb 2012
    Folsom, CA
    Default bowl question
    The guy I bought my boat from told me that he had rebuilt the jet and had flipped the bowl around. Is this good or bad?? And are there any advantages/disadvantages to doing that?
    Nathan
    Senior Member eliminator's Avatar
    Roanoke VA
    Quote Originally Posted by monstertahiti78 View Post
    Nathan
    Thats a new one for me . Is this another E bay racing trick?
    MD
    it's a goodthing and will give you about 20mph more on ebay
    he may have rolled the bowl too put another nozzle on
    post a pic
    Nathan
    There are a couple things that come to mind , if the Oil bath fill plus are 2 and 4 (vs 10 & 2) it could have been "clocked" to use a Berkeley Jet o Vator if the fill plugs are now elswhere from traditional and it (the bowl) has been converted from oil bath to grease lube (zerks vs plugs) it doesnt likely matter in the grand scheme ,but dont understand the reasoning and would look odd IMO Tom
    Feb 2012
    Folsom, CA
    Would having the bowl flipped create more downward pressure off the nozzle without having a jetovator? more or less a "poor mans jetovator". This is what the bowl looks like now...
ID:	151272   Click image for larger version.
ID:	151273   Click image for larger version.
    Thats just your bowl upside down...no jetavator.
    Atlanta, Texas, United States
    Monster,
    I am fairly certain a JC bowl is neutral at the nozzle. I can't imagine why anyone would turn it upside down. With it upside down you cannot put lube in to lubricate the shaft and bushings. IMO you should reindex it 180 degrees and fill the bowl with lube. Am I correct on this Tom?
    Gear
    Quote Originally Posted by Gearhead View Post
    Monster,
    Gear
    Gear and Monster , IF the bowl is now "Grease lube" (not oil bath) short of "jacking" the seal out you should be able to pack enough grease into it (one fill plug removed) to make it work , whatever the "motive" or logic was by the installer to install it that way still escapes me however, chances are the bowl maybe cracked or "prior repaired" (most common reason to fill it with grease which it wasn't designed for) or the line bore may be off , tail shaft bushings misinstalled or the bowl or suction mating surfaces warped or mismachined (seen this after powder coat) our someone was rotating the bowl for percieved "fitment" issues, The problem is once grease lubed , bascially forever grease lubed, its damn near impossible to heat/clean/ evacutate grease from the inner cavity won't say we havent ever done this (converted eg bore and sleeve) but would prefer to Keep Berks oil bath from I'd pull the bowl and inspect the corona area around the tailshaft bushing area carefully for cracks welds etc C bowls are cheap and plentiful Tom
    Mar 2010
    Clarksville, TN
    Its simple, somebody told him it added 10mph so he done it
    Colfax, Ca
    Rotate the bowl.
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Default Bowl
    Nathan
    PM sent
    TbT
    Senior Member wolfie's Avatar
    The guy probably put it back together and then realized he installed the bowl up-side-down by mistake and figured he could tell the next buyer it's a performance upgrade.
