Aluminum I-Beam jet boat trailer?
Results 1 to 14 of 15
    okie, lake Texoma
    Default Aluminum I-Beam jet boat trailer?
    Why dont you see some of these? I see the aluminum I-Beam under everything from small single axle junk to the very large boats. The stuff stays looking great and from what i can tell it would be very easy to change the axle arrangement from dolley trailer to regular axles-back & forth. Is it so light that the tires would make it float?
    why couldnt one of these be built
    while using some of these frame materials?
    H8-2-W8
    [email protected] first pass
    Apr 2009
    San Diego, CA
    More common in salt water applications and big boats to save towing weight.
    I think brad Parrack had one.
    Senior Member SEEIN RED's Avatar
    HOUSTON TEXAS
Name:	dolly trailer.jpg
ID:	151432 Is this what your tAlking about . We have had this one about five years. lt's lite and tows great.
    Southwest corner AR
    I think some of the issue is cost! Alu. has gone up quite a bit! Nice trailers!
    WT
    WFL Crew!!!
    Senior Member Tony Skagen's Avatar
    Heres one thats in my shop right now.
    bfp
    bfp is offline
    Top Fuel Jet bfp's Avatar
    ca.
    I did have an all aluminum dolly trailer as Mike indicated ,but it was chanel on the rails, I- beam cross members. Very light, but it is cost prohibitive. It cost me 3 k in aluminum alone, plus the hubs, springs, hangers, equalizers, wheels and tires. We built our own axels, and built the trailer. BTW box frame trailers are the ones that float, which isn't good in my opinion.
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Quote Originally Posted by bfp View Post
    Anybody that builds a trailer out of I BEAM must be a STEEL WORKER.
    Senior Member TexasJet's Avatar
    College Station, Texas
    McClane Trailers in Houston makes that type. I have a double axle for my 19' boat. It will float if you back the empty trailer in to far. With a little cross wind it will start to float off center.
    bfp
    bfp is offline
    ca.
    Quote Originally Posted by PCE680 View Post
    or one of your drivers!
    okie, lake Texoma
    Quote Originally Posted by SEEIN RED View Post
    That exactly what I was talking about, figured someone had made one, thanks.
    H8-2-W8
    okie, lake Texoma
    Quote Originally Posted by TexasJet View Post
    Thats kinda what I was affaid of.
    H8-2-W8
    bfp
    bfp is offline
    ca.
    Hass mine never floated. But all the weight was on the tires, not on the tongue. By design.
    HOUSTON TEXAS
    Never had a problem with mine floating .Cross braces are square tubing and fill with water maybe thats why .
