Droop snoop studs
Results 1 to 6 of 6
Droop snoop studs
    Retired Air Force Master Sergeant's Avatar
    Lake Havasu
    Default Droop snoop studs
    I want to use stainless steel studs to connect the bowl to the snoot to prevent corrosion. Steel studs rate at 125,000 psi tensil while the stainless steel rate at 75,000 psi. Are they strong enough? I have 850hp
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Default Bowl studs
    Quote Originally Posted by Master Sergeant View Post
    If its double bolted stainless steel should be good.
    Ron
    One less DEALER means more DISCOUNT for you
    Lake Havasu
    No, only 8 bolts
    ATM
    ATM is offline
    Amerian Turbine Man
    Clarkston, WA.
    Default Bolts
    No, only 8 bolts
    With 850hp I think it should be double bolted. The threads in the bowl are more prone to pull out than anything else.
    Ron
    "Member" suckfish81's Avatar
    ARP makes real nice s/s stud's they've worked real well for me. And that much HP double drilling is a good idea. just my .02
    B1 Racing cs19's Avatar
    Id like to see anything over 750 hp double drilled everywhere.
    B1Racing.net
