Impellor ?
Results 1 to 2 of 2
Impellor ?
    Southwest corner AR
    Default Impellor ?
    I was wondering if a AAA impellor is the same as a 9.5 or is it different size? What is the difference?
    WT
    WFL Crew!!!
    B1 Racing cs19's Avatar
    If you measure the large OD of the impeller yeah it would be a 3A but there is typically an angle change at A and above and this has an effect on the load. For example you can run a big impeller in a berkeley style bowl that is only bored to 9.125 so the shroud is still small so it fits in the bowl but it could have a shallow angle machined on the exit side that can make it work like a large impeller. When you get into the larger cuts you have to look at all this to figure the cut size.
    B1Racing.net
