v-drive. oil pan
Results 1 to 3 of 3
v-drive. oil pan
    Nov 2012
    Default v-drive. oil pan
    how do I get the oil level correct with out the stock dipstick application? this is a canton oil pan with an access for a stick? 350 sbc.
    Senior Member phughes SS-13's Avatar
    Jun 2012
    Sarasota, Fl.
    Default Fill'er up
    With the pan on the bench (off the engine) fill the pan to the correct level with a measured liquid. You can use water, but I prefer not to. Insert the dipstick and mark it at that level. Now you know how much the pan holds and have a properly marked dipstick. You will need to add additional oil to account for oil lines, cooler, filter, etc. That should do it.
    Nov 2012
    Default v-drive oil pan
    Quote Originally Posted by phughes SS-13 View Post
    Thank you for the help!
