63 v-drive needs reverse
Results 1 to 5 of 5
    Feb 2012
    El Dorado Sprgs,Mo.
    Default 63 v-drive needs reverse
    I have a boat that I've been working on??/ Its got a 390 Ford FE engine with a V-Drive??/ I'm trying to get a reverse in it without a lot of room to work in??/So I was considering a adapter for the FE ford to a power glide??/Is there a combination that you know of to perform this task??/Bell housing adapter,Tail shaft and tail housing removed and a coupler installed any thing to gain space between the engine and V-Drive??/ I was looking at a( see pic's below) Direct Drive for Power glide, What would be nice if I could eliminate the bell housing ( with the add if available of a adapter that mounts the PG transmission less bell housing right to the bolt pattern on the back of the FE engine) I have a source that sells a Direct Drive for Powerglide (SEE PIC's) also they sell a Direct Drive converter but again I would like to get away from the bell housing something similar to a velvet drive without the bell housing any ideas or sources for a adapter plate (mechanist??/ Maybe someone that's got one of this on the back shelf) in place of the bell housing Please advise Steve Also have you ever seen a powerglide in the pic ??/ (Small bell housing) The other pic is of a glenwood that I redone back in the 70's
Name:	in out box with the tail shaft.  Race Turbo Case. any Chevys from 1955 to current..jpg
ID:	322913   Click image for larger version.
Name:	Direct Drive for Powerglide.jpg
ID:	322921   Click image for larger version.
Name:	1st Boat at Big Bend.jpg
    Senior Member Mouzer's Avatar
    corona ca
    jw will see this shortley but i would post this up in the v-drive (tech)section
    ''''''OWNER OF THE BIG WHITE WOLF....,,,
    Cocoloco cocoloco's Avatar
    Aug 2011
    Pacific Beach / Parker Strip
    Default I did this dance.
    Quote Originally Posted by stevejohnson48 View Post
    I waited and debated then even bought a powerglide. Having raced one for years I was comfy with it. Then I started thinking about cooling it, mounting it, propping for it, gearing for it and all the mods to run it. After six months of debate the Velvet drive won out on a lot of points. I sold the Glide and bought a velvet drive which I am installing when I reassemble the boat next month. My Dos Centavos Amiger.
    Feb 2012
    El Dorado Sprgs,Mo.
    Default Reverse in V-Drive
    Cocploco < Hay when you do finish this setup can you get back to as to the procedures you went through to get the ride back on the water ??/ Your still going to have to cool it right , and maintain a hydraulic reservoir aren't you ??/ I was looking at the cost between the two at one time ??/ the PG looked more appetizing at the time looked into a Lenco and couldn't justify not being able to get reverse without coming to a complete RPM idle ??/ Get back to me on this ??/ A couple of moe pic's as to the app??/
Name:	Ford FE to PG.jpg
ID:	807386   Click image for larger version.
Name:	Chevrolet Corvair Powerglide.jpg
ID:	807394   Click image for larger version.
Name:	Casale top loader #1.jpg
ID:	807402   Click image for larger version.
    waterloo
    I have a 68 Donzi with v drive. It has a trans with reverse. It is a velvet drive, or borg warner, or something old like that. It is in and out of forward/ reverse so easy, people compliment it.
    Wags
    Velvet Drive - Marine | Products
    Or borg warner makes velvet drive??
