Hallcraft Rudder Packing
Results 1 to 7 of 7
    Nostalgia Flat 01 Rigger's Avatar
    Huntington Beach, Calif
    Default Hallcraft Rudder Packing
    The 1977 Riviera I am restoring has a Hallcraft Rudder assembly. The boat sat for many years and the Rudder has a lot of slop in it. I disassembled everything, cleaned it up & replated the Rudder. There was no shaft seals installed. The Grease Fitting on the Shaft Log is good. Do I just pack the snot out of this with waterproof grease for a water seal?
Name:	Riviera 12-23-11 005.jpg
ID:	416425   Click image for larger version.
    Pictures after re-installation. I have put quite a bit of grease into the Rudder Shaft Log and it seems to be taking away some of the play. Just not sure how much grease to pack into the Log.
ID:	416441   Click image for larger version.
    Junior Member GN107's Avatar
    Feb 2009
    Lake Havasu City
    Why don't you send us a picture of the top of the rudder box. If there are no seals or stuffing material you might want to replace it while you have it apart
    Connolly Marine - High Performance V-Drive Boats
    Default Hall Craft Rudder Shaft Log
    The Rudder Shaft Log I.D. Is 1 1/4 inch. There are packing rubber seal rings at top and bottom of Shaft Log inside, see pictures. Rudder Shaft O.D. is 1 1/8 inch. Looks like I just need to replace both rubber seals. Where might I find these?
ID:	427785   Click image for larger version.
ID:	427793   Click image for larger version.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    bump
    QE 439 Twin Turbo
    Senior Member swtd's Avatar
    Sep 2008
    beaumont ca
    Default Seals
    Quote Originally Posted by Rigger View Post
    Ace Hardware take old seals to match. Careful installing shaft to not pinch or roll them during assembly.
    Diamond Bar, Big River
    Default o-rings
    oringsandthings.com their located in Fontana Ca. They should have what you need.
