No Speedometer
Results 1 to 6 of 6
No Speedometer
    Former HB visitor Old Man Havasu's Avatar
    Alta Loma Ca and South Lake Havasu
    Cool No Speedometer
    Speedometer on my Hallett 270 just stopped working? Where is the sending unit/intake located?
    Ideas?
    I live in Alta Loma, "I live life in Havasu"
    If it's force fed water speedo, the pick up (pitot tube) could be mounted on the transom (hangs below the bottom of the boat), or the more likely scenario the pick up is located at the front of the out-drive.
    Lead, follow, or get the hell out of the way!
    Morgan Hill
    If a late Merc. its just above the nose cone (small hole), most times gets plugged from hitting debris and plugs the hole, somtimes they blow the hose out at the mating surfaces of the drive, cheesey little plastic POS.
    Good luck!
    BTW GPS Speedo's are the bomb!
    GT
    GT
    Quote Originally Posted by H2oSki2Fast View Post
    Good luck!
    GT
    Heading out Tuesday night. I will check for a block. Hope I don't have to drop the thing to connect a POS hose.
    Thanks and Happy New Year
    I may just rely on the handheld GPS!
    The Pool Bitch phebus's Avatar
    Lake Havasu City, AZ
    Quote Originally Posted by Old Man Havasu View Post
    It's really cold out, so your ears freeze at 40, and the tip of your dick breaks off at 60. Who needs a speedo?
    Usually it's the little hole on the front of the drive, a small drill bit turned in by hand will unplug it. If you're coming to Havasu and need anything, let me know.
    No you don't.
