Sure Could Use Some Advice On Rigging
Results 1 to 3 of 3
    Fastfunco fastfunco's Avatar
    May 2014
    2964 E Cupa De Oro Dr. Mohave Valley Az. 86440
    Default Sure Could Use Some Advice On Rigging
    I sure could use some advice on rigging this boat I made - It is an exact copy of a RC boat that was unbeatable - so It works well- but with outboard steering strut etc-- no time for that and unnecessary on this build - this boat im keeping and the only racing it will do is up and down the river - Can you guys help me figure out some hard dimensions-
    its a 5/8 runner bottom for the most part- it is all carbon fiber and kevlar - 2x6 stringers transom to bow tapering all the way forward- boxed in with a nose bulkhead and the one in front of drivers feet-
    boat is 15 ft 2 inches - and 16 ft exactly if you add the 10 inches of plates sticking out
    Engine is 1500 hp blown injected alky- all cast iron so its heavy but mostly to retain heat was the reasoning
    3 fuel tanks since its a riverboat - 8 gallon stainless steel tank up under the wing is main tank feeding the mechanical 110 pump- 2 side tanks are 15 gallons each stainless as well- going to run a standard holley mechanical pump off cam that pulls fuel from both tanks into center tank- center tank has 2 return lines at top of the tank - 1 on both ends of the tank that will let fuel go back to side tanks and keep 8 gallon tank full while boat is running - i have a weight concern all of a sudden- little boat with massive cast iron engine and 38 gallons of fuel-- will this be ok??
    since there is no data on this short of a boat
    Should i set the engine first ? and work on keeping the CG correct - where would the CG be best - usually of turn fin- but i dont have a location for that either ???
    or
    Do i work from the strut being placed first ?
    I thought i knew what i was doing building this thing- but im about 30 days away from rigging this boat and i have no solid plan together
    im just looking for some ideas gents - not wanting to nail anyone down on this - I just dont have the experience to know what will possibly work and what definitely will not - so any advice sure would be appreciated -my goal is to have minimal holes in the bottom when i finally get it dialed in - as you can see i spent tons of time with the graafix on this project - its all gelcoat too--not done in the mold - 1 color at a time - never again!!!
Name:	all phone pictures as of 9-2018 2820.jpg
ID:	1026635   Click image for larger version.
ID:	1026637   Click image for larger version.
ID:	1026639   Click image for larger version.
ID:	1026641   Click image for larger version.
Name:	all phone pictures as of 9-2018 2764.jpg
Name:	all phone pictures as of 9-2018 1792.jpg
ID:	1026645   Click image for larger version.
Name:	all phone pictures as of 9-2018 2199.jpg
    Old Timer LeE ss13's Avatar
    San Dimas CA
    Drop the Boat, the Engine, any other parts you have and a 10 lb box of $10s at Bergeron's in Mesa, and he will hand you back a complete Lake Monster.
    I don't know what I don't know because I forgot !!!
    Quote Originally Posted by Freedom Child View Post
    They all look alike upside down
    Quote Originally Posted by Wannabe View Post
    A grace of the English language that you obtain simply supersedes all reasonable expectations.
    Sep 2009
    Walled Lake, Michigan
    Hello, I do not have answers for your hardware placement and I see this is over a year old. But I think you have a really cool boat here with an insane amount of work in it. Interesting bottom graphics and all gel coat. I assume you have made progress since this post and likely have the boat running by now. Interesting bottom design and overall length. Thank you for sharing. Darin
    Margaret Thatcher once said The trouble with socialism is that eventually you run out of other people's money.
