another motor placement ?
Results 1 to 5 of 5
    Senior Member ugly duck's Avatar
    Jul 2010
    OGDEN UTAH
    Default another motor placement ?
    i have a 74 eliminator spider , has had lots of setups from the looks of the motor rails . vdrive plate 100 inch from transom,7* strut mounted center of strut 23 inch from transom, 18 inch cav plates hangin 11 inch out, big chev flywheal drive thats mounted 27 inch from transom. just wondering what you think on how close or far from a usable set up this is or what i need to move. spends most its time at the lake or trips to the avi no races . its an old pc boat so its got some cool hardware and setup but it seems it was just thown together this last go around, the gears are 12% ....i was told ,if it maters thanks for any help an sorry for the grammer ,its not why im hear
    Jul 2010
    OGDEN UTAH
    anyone have any thoughts on this? if i havent given the corect info could someone maybe help me out with what it is im suposed to put? or beter yet is ther a furmula i could learn to figure out where the motor goes, strut angle with length and distance from v drive to prop or whatever. If so, a little push in the right derection so i could figure it out without going through 6 drivelines would b GREATLY APRECIATED
    Senior Member Charm Skool Reject's Avatar
    Nov 2010
    Clayton, WA
    Default Spyder
    74 Eliminator Spyder? Cool, show us some pictures. I bet you would get a lot more feedback if you posted this thread under "V-drives"
    Jul 2010
    OGDEN UTAH
    Quote Originally Posted by Charm Skool Reject View Post
    Thanks ill give that a try, seems like all thay like are b/k boats so i wasnt to shure figured id try wilkes., any way thers more pics on my page tryn to get some better ones , recently lost most of them to a fire
ID:	117537   Click image for larger version.
Name:	DSC04901 - Copy.jpg
    Jul 2010
    OGDEN UTAH
    i have been schooled, my paper work is off she is a elimenator but not a spyder (difrent botom) i stand corected
