75 spectra neovane pump
    Sep 2011
    Default 75 spectra neovane pump
    dissasembled pump all looks good wont draw water 460 ford 3 bolt mount options for somthing else checked drive on cam ok water flows good with forced water 24 foot day crusier v drive sure would like to toss in trash can would like to go electric has down tube below transon not that familar with this assumeing this tube is force fed when boat is at speed checked hoses old butt look ok only thing i can come up with is suking air
    Senior Member SHADOW 21's Avatar
    Sep 2009
    GREENSBORO, NC
    Make sure you have the cover installed in the right position on the pump, I put mine on upside down and had the same problem.
    Sep 2011
    Default neovane
    pump 105 2cover screws with in out arrows on top could be distorted has an oval shape new impeller new motor test fired with garden hose at the boat launch got hot quick tried to run it to force water in from down tube didnt work pulled pump thinking impeller would be trash nothing wrong must of had somthing there
    Senior Member Flat BROKE 612's Avatar
    Feb 2010
    Bumblefvck PEI
    Quote Originally Posted by dazed View Post
    Do you live where there are freezing teperatures? If so the pump was prob not drained properly and the cover is pushed out losing seal with the impeller... measure with impeller thikness with calipers and the cover depth... carefully press back or buy a new one
    If you love someone set them free, If they come back with the cops...RUN!!!
