Livors GPS Speedometers are driven by a GPS antenna for accurate reading and reliability. GPS Speedometers are available in standard or over sized cutouts with several color options.
Our updated GPS antenna models are now built with out a battery and with the ability to be mounted underneath the dash. This means you no longer need to have a awkward piece disrupting the look of your beautiful dash. Best of all there is no calibration required.
Antennas are NMEA 0183 compliant/compatible which means you can use these with any display that accepts a NMEA 0183 input. and NO CALIBRATION REQUIRED!
Mega and Race Series GPS Speedometers are available in standard or oversize with 5 dial options, several rim colors and two rim styles to choose from.
GPS SKI
mega and Race GPS Ski Speedometer is available in standard or oversize cutout. This gauge features an expanded scale from 10 to 40 MPH. 5 dial options, several rim colors and two rim styles to choose from.
GPS Speedometer with Odometer
This standalone GPS Speedometers with Odometer is a digital gauge driven by a gps antenna with a 10X update. Combines both analog and digital readouts in one gauge. Built in odometer helps you determine your GPM.
Livorsi even has a GPS Antenna for those of you with an electronic speedometer in your vehicle. With the use of the GPS Pulse antenna you may convert any brand electronic speedometer into a GPS driven speedometer. This means no calibration!
Visit our website for more information Livorsi Marine, Inc. - GPS Antennas, NMEA 0183 Receivers, GPS Pulse Antennas, GPS Antenna Replacements for GPS Speedometers
