Need 460 oil pan for a jet boat.
Results 1 to 8 of 8
    Senior Member unstable's Avatar
    Apr 2012
    Pontaic MI
    Default Need 460 oil pan for a jet boat.
    I need to buy a oil pan for my jet boat. It has a ford 460 in it.
    Thank you
    Leroy
    Jul 2009
    jackson , michigan
    Quote Originally Posted by unstable View Post
    Thank you
    Leroy
    has that boat been good to you .
    Apr 2012
    Pontaic MI
    Quote Originally Posted by johnnywalker View Post
    Not really this is the third engine in it. The first one threw a rod (grenaded) the 2nd time out with it. Then i bought a used engine to get me thru summer and it lost all oil pressure. So now i am on E-3 so i went with a built 460 with around 550 hp. Are you the guy i bought it from? I love the boat just trying to get it going for summer. I dont want to use a stock oil pan.
    Jul 2009
    jackson , michigan
    no i just seen the boat for sale a year ago or so .
    Jun 2010
    check on summitracing.com you should be able to find a pan at a reasonable price,,,,
    Jul 2009
    jackson , michigan
    if you put a hv oil pump in it you will want at least an 8 quart or more pan . them jets run around at 3000 plus rpms . just running around . try that 460ford.com for an oil pan to .
    Orlando.FL
    Armando builds a nice 460 pan, also I would perhaps run a oil accmulator with a 460 also.
    Pm Adam or Jeff here @ MHB...They might know where to locate one.
