432 Build
Results 1 to 14 of 27
432 Build
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    Default 427 Chevy Build
    This section needs more builds. I've started to assemble the BBC that will eventually end up in Shep's Aquacraft.
    Specs:
    454 .30 over, line bored/honed
    396 steel crank
    Clevite bearings
    Dimpled rods w/ bushed small ends, 7/16" ARPs
    SRP 212133 427 pistons w/ 30cc dome, full float
    Doug Herbert hyd. roller cam, CBH8 (10.1:1 comp) 245/255 dur, .595/.610 110 lobe, 2800-6800
    Doug H. hydraulic roller lifters
    049 heads worked over w/ isky springs, retainers
    Edelbrock Torker II intake
    Bedded the crank last night. Spins sooo smooth.
    oldsmopile equipped
    Lake Lansing MI.
    thats great bud, why the 396 crank? just what you have or??? sould run good!
    Waterford, MI
    The motor is a mix and match of what MHB had lying around the garage, big thanks to those who offered up parts for sale.
    Jun 2010
    Quote Originally Posted by Elkidminoltu View Post
    Well actually its a steel 427 crank but I ran the snot out of the boat its going in with a .030 over 396 for ten years, it will be a great laker for Dave and thats all I got to say about this.
    Quote Originally Posted by mdsheppie View Post
    I am getting ready to do the same thing. I think the only thing I need to buy will be bearings, cam, and pistons. Still do not know it I want to go 454 or use a 454 block and 396 crank. or 396 block and 454 crank. I guess a smart guy would go all 454. But for you that know me...well I doubt you ever said I was smart.
    Jun 2010
    Evil I'd go with a 454 block,you would have to grind reliefs in a 396 block for crank clearance.
    kachinatim
    May 2012
    fenton,mi
    Default 427 tall deck marine
    shep do you know a good shop who can machine my block and clearance for a 4.5 stroke thanks tim
    Jun 2010
    Ross automotive in Lapeer they do good work 810-667-3000 ask for Chris...
    Hows it going Tim?
    kachinatim
    May 2012
    fenton,mi
    Ross automotive in Lapeer they do good work 810-667-3000 ask for Chris...Hows it going Tim?
    real good just bought a 67 chevelle gonna pro street but need to get the boat done first,i will call them guys need to get this motor together
    Michigan
    I'll second that.
    kachinatim
    May 2012
    fenton,mi
    Quote Originally Posted by Brandon View Post
    I'll second that.
    to many projects and that honey do list
    Waterford, MI
    Two years later I ordered the valvetrain from Straub so we'll get this puppy put together and fired up this spring.
    Senior Member unstable's Avatar
    Apr 2012
    Pontaic MI
    Still going in the Aquacraft or putting it in the jet?
    Jun 2010
    Not going in the Aquacraft but it will be going.
