1977 wriedt jet boat winter build
Results 1 to 14 of 75
    Senior Member unstable's Avatar
    Apr 2012
    Pontaic MI
    Default 1977 wriedt jet boat winter build
    Well i am new here this summer and only made it to one event. I have met some of you and hope to meet more at the winter party. I bought my boat this summer and i have had alot of bad luck with it. So i am going to go thru the whole thing this winter so i can spent next summer on the water and not working on it.
    This is when i first got it. Its a 77 19ft wriedt with a 460.
    Jun 2010
    Almost met you at Holloway, maybe at the party
    Apr 2012
    Pontaic MI
    I ran it a few times with the water logs and everything was good. Then i threw on the bassett headers it came with. The first time out with them on my second lap around the lake i threw a rod out of the oil pan. I didn't want to spend the time to rebuild the engine so i found a junk yard one to get me thru the season. Well that one lost all oil pressure one it was warm. Then a friend of mine said he had a built 460 he wanted to get rid of. So i got that it was broke in and that's it no hrs on it. Its a 460 .030 over with roller rockers and 429 super cobra jet heads. So i installed all of that and it ran good for about a month. Then at the holloway reservoir meet i sucked up a bunch of rocks and trashed the impeller. So decide i would take it to browser's for hot boat weekend. I made a good run down the the sand bar from the campground and back. When i get back to the campground it missed and started running rough. Well turns out I dropped a valve.
ID:	184146   Click image for larger version.
    MI
    I have all the jet pump tools if you plan on rebuilding the pump.
    Apr 2012
    Pontaic MI
    Quote Originally Posted by sanger rat View Post
    Thanks rat i might take you up on that. I have it torn down and its not pretty. The nice thing about being a machinist and having the shop at my disposal is i can make some of my own tools.
    MI
    The valve probably stuck in the guide. You can't run a street motor in a boat with open cooling. All the clearances need to be looser. The block and heads stay ice cold but the oil heats up the pistons and everything else.
    Apr 2012
    Pontaic MI
    I torn the pump down this weekend its a Berkley JC pump with a aggressor 9 vane bowl, droop snoot and place diverter.
ID:	184148   Click image for larger version.
ID:	184149   Click image for larger version.
ID:	184150   Click image for larger version.
    MI
    Quote Originally Posted by unstable View Post
    I have the spline socket for the shaft, impeller puller and a custom socket to fit the impeller nut. Jetboat is long gone but I kept the tools just incase.
    MI
    That bowl has seen some abuse. Wouldn't hurt to clean up all the nicks on the vanes. Thats a high dollar bowl you got there.
    Apr 2012
    Pontaic MI
    I am going to go thru the whole thing this winter. I also want to stiffen up the hull a little. I am going to order some new over the transom headers so they will fit my 429 scj heads the ports are alot bigger then a stock 460.
    Apr 2012
    Pontaic MI
    Whats the best way to finish them flat on the bottom and angle the top. I am sure you dont want them sharp so round the edge a little?
    MI
    When that front blade broke off it took out everthing else on the way out the bowl..Stainless or bronze impeller is the way to go.
    MI
    If it were me I would send it out to one of the pros out west and have them detail it. Jet Boat Performance, HOME
    Apr 2012
    Pontaic MI
    Quote Originally Posted by mdsheppie View Post
    See you at the party.
