spring
Results 1 to 14 of 40
spring
    Senior Member verman's Avatar
    Aug 2012
    blanchard mich
    xxxxxxxxxxxxxx
    Jun 2010
    So you just figured out the lakes are still hard ?
    Jul 2011
    kalamazoo
    Default spring
    my lake is open but some of the others have swimmin ice
    Liberator Stealth
    Jun 2012
    Michigan
    Look good Larry. Did you get that motor raised up? Run it as high as to can then your going to see the big number.
    It was 44 outside yesterday and it felt like summer. Christine was ready to uncover the boat while I checked out the ramp.. The ramp was a no-go and the lake still has sled tracks
    Junior Member Nmliberator's Avatar
    Feb 2013
    Verman how do u get that scale off of your mid.
    A old trick to clean the scum off the black outboards is to use lemon pledge...
    Liberator Stealth
    Jun 2012
    Michigan
    Quote Originally Posted by michael thomas View Post
    it was 44 outside yesterday and it felt like summer. Christine was ready to uncover the boat while i checked out the ramp.. The ramp was a no-go and the lake still has sled tracks
    that sucks mike
    Larry, years ago we always wiped the engine down with pledge after we got back to the ramp. Waxing was a pain in the ass when the engine covers were grainey like cowhide. Your shit will sparkle. It takes off water spots with ease...I use it on my hull to remove the mineral deposits..I don't wax my boat, but was told the pledge will remove wax.....so does Dawn.
    Jul 2011
    kalamazoo
    Default spring
    my buddy bought a boat that sat in a river the bottom of the boat was all brown from staining and the outdrive was all white with nasty scale i took a bug sprayer put muriatic acid in it sprayed the bottom and the outdrive the brown ran right off and let the out drive soak spraying it once in awhile it came out brand new looking the fumes are excessive so you have to watch out for that but all you have todo is rinse it with water works well on rusty parts as well you guys probably know that i use it all the time on nasty parts and such
    Bah... HST4ME's Avatar
    Michigan
    Usually a 12 pack of Budweiser on the nearest picnic table will keep the scum away from your motor for awhile.
    Jun 2010
    Quote Originally Posted by HST4ME View Post
    Thats so 2011 Lynn now its two bottles of Jack- a jar of moonshine and a bottle of the captain////
    Senior Member Wildfire's Avatar
    This sounds like Alcohol abuse to me. Chet
    1992 Stealth Edge
    468 BBC 670hp-dyno
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    The lake here is almost fully thawed. Might be time to shake the windows.
