Question for the blower guys.
Results 1 to 7 of 7
    Member AWDGSX's Avatar
    Sep 2012
    Default Question for the blower guys.
    I'm trying to figure how much boost I can get away with on 91 pump gas.. 496 BBC 8.0 to 1 Iron heads..
    It's a jet and I know that should make a little difference. The blower is only making about 5psi right now. I'm running 30 degrees total advance. I set it at 32 on the dyno but wasn't gaining much power anymore with the last two degrees so I dropped it back to 30.
    I have a boost retard but it's set to zero. The cam is a 114 and 288 duration so the cylinder pressure is probably pretty high even with the low compression..
    If this were a turbo I would just keep turning it up and watch for sparkles on the plugs but buying pulleys isn't free.. lol
    Big block chevy's are not my normal thing so any help would be greatly appreciated.
    Jun 2010
    Quote Originally Posted by AWDGSX View Post
    Nick I would stop at 9 % over,pullies are only 70 -80 bucks motors cost more
    Sep 2012
    Quote Originally Posted by mdsheppie View Post
    I'm already at 9 over but it's only making what it is.. same 9% made 9 psi ish on the 454.. I would think I could pulley up the difference in cubes back to 9 psi again atleast? I'm starting to think this is a 6-71 and not an 8?
    Jun 2010
    try going to 15% keep an eye on your plugs is your blower stripped or just plain rotors?It looked like an 8-71 at Wamplers last year
    Michael will get on here and splain it all real easily
    Sep 2012
    Just plain rotors..
    MI
    Just plain rotors..
    Don't bother trying to make any more boost your just going to superheat the air and have a meltdown. You are going to need to upgrade your blower with some teflon strips if you want to make more boost.
    Std 6:71 = 15" case and rotors...411 ci
    Std 8:71 = 16" case and rotors...436 ci
