Boat broke
Results 1 to 7 of 7
Boat broke
    Michigan
    Angry Boat broke
    Exhaust logs are leaking at the flanges due to warpage and a crack. I have a set of logs(thanks!), that I want to run if I can get my snails off (I need the 90 deg. off mine), but the oil filter bracket hits the logs. Perfect timing!
    Happy fourth to you and yours!
    Senior Member Wildfire's Avatar
    You call that broke??? Stop over to my place and I'll show you broke! Crankshaft is in 3 pieces,cylinder wall gone, rod bent so bad you can't remove the third piece of the crank and the camshaft is bent so bad it can't be removed from the block. That's broke!!! We'll probably be down for the rest of the season but hopefully she'll be running in the spring. We're not cutting any corners. Brandon tell your "Bride" that "Wildfire" will be back and in rare form. Chet
    1992 Stealth Edge
    468 BBC 670hp-dyno
    oldsmopile equipped
    Lake Lansing MI.
    do you mean that the logs I gave you are hitting? if so you can run a remote oil filter, or I have a olds diesel oil filter mount you could try to see if it will clear, they are a bit different. also I think you can buy a header flange for an olds from summit or jegs, you could use that as a spacer, that may help. how far off is it?
    Senior Member Chop Shop's Avatar
    Oct 2011
    Puget Sound Wa
    My boats fine, but IM broke!!!
    Senior Member unstable's Avatar
    Apr 2012
    Pontaic MI
    If you need i can cnc you a spacer. Maybe i could make a adapter to rotate the snail if that helps.
    Michigan
    Quote Originally Posted by Wildfire View Post
    ya I guess mine isn't so broke. This stinks for wildfire.
    Quote Originally Posted by Adam View Post
    ya they will hit and also I need to be sure when they bolt to my snails the snails mount properly too. I did get to see fireworks from the water on the 4th. Repaired mine, so far so good. Put 16 gallons of fuel through it this weekend.
    Quote Originally Posted by Chop Shop View Post
    Quote Originally Posted by unstable View Post
    I may be taking you up on something like this.
    Hope everyone had a great weekend!
    Michigan
    Default Still broke. Well kinda.
    I did try and duct tape the flange with the stuff you see at the snow show. The guy with the pop can, butane and a rod. It worked very well till it saw a period of wot. Now I have a beer can doing the job. So it's running and we will be on Holloway today. No time for working on it with this weather! Hope to see some of you guys out there! See you on the low pro side!
