e 85 carb jetting
Results 1 to 9 of 9
e 85 carb jetting
    Jul 2011
    kalamazoo
    Default e 85 carb jetting
    i sent out my 1050 dominator to be converted so far i am not even close on the jetting the jets are so large now that the blocks will have to go to methanol size jet holes me and shep have been talking bout it i was just wondering if anybody else has run into this got a bunch of money tied up in the carb and am sick of screwing with it thats why i sent it out. anyway what mains are you guys running i know you need engine specs but i want to see where everybody else is at my is 460 c.i. bbc 13.5-1 655 lift claysmith cam 274 278 @ .050 i probably will end up sending it back but wanted to see where you guys were thanks for any help Alan
    MI
    Sounds like you need to change to smaller idle air bleeds. Who did you have do the Carb?
    Senior Member 65BEAVER's Avatar
    Nov 2008
    livonia mi
    I run a .134 pin on a 444" S.B. made 820hp N.A. with shit exhaust!
    Senior Member flattie's Avatar
    Menominee mi
    My jets are huge in my e-85 motor The instructions said jet up 6 sizes Im up like 12 sizes from what I was on gas I want to say I have like 89s in the primary side and 99s in the secondarys on my tunnel ram motor
    Mar 2013
    Saginaw Michigan
    Sorry to butt in but i'm looking for a carb shop to send my dominator in to. Anybody in MI. that's good with the older mini dom's that could rebuild it ?
    Jul 2011
    kalamazoo
    Default e 85 carb
    I had my carb done at race on e85 by Justus Daniel right now I am going to check a few other things before I condem the carb my jets are so big that I will have to redrill the blocks to methanol size I have them drilled .171 thou. and it is so lean it would scare you I found a guy in Kentwood mich. its called horsepower innovations heard they do good work any way thanks for the help I will update you guys on what I find weather its on my end or the carb is bad
    MI
    Chris at Classic Motorsports did my Dominators for my blower motor and my E85 jets were only a couple sizes larger than the gas jets. Her's a little tech on air bleeds. Treat them the same as jets. Carb Class: Air Bleed Basics
    Jul 2011
    kalamazoo
    here are my idle air bleeds. .055 high speed air bleeds are .024 any smaller and they would be plugged i could have a vac. leak or it is sucking air some where when it quits raining i will take some carb cleaner and spray around the manifold and carb base if it picks up rpm its my end if it dont its got to be the carb when i got it i had to turn the idle mix screws 5 1/2 turns just to make it try and idle he sent me some #54 idle restictor jets in the metering block that cured the idle issue theres no way in hell i should have to go to methanol jets to make this work i talked to rob mix & mark sullen they both think either air leak or something wrong with the carb rob mix says with HS bleeds at .024 there was all ready a problem get fuel before i even got it i could take the mains out and it still wouldnt be rich enough anyway i hope i can find something soon i got 850.00 big ones in it and a bunch of time screwing with it. it may not be a pile of money to you guys but it is to me. pretty damn expensive paper weight lol I thank you all for your thoughts Alan
    MI
    Kinda hard to tune a carb over the internet. One spec of crud in there somewhere could really mess things up.
