Need a Jet Pump Guru
Results 1 to 6 of 6
    454gullwing
    Dec 2012
    Default Need a Jet Pump Guru
    Hey All -
    I am in need of someone to go through my Berkeley pump and evaluate the setup. Close to Southeastern MI would be great. Running an 18' Gullwing and upping the power plant to 650 hp. Thanks in advance for the help!!
    Jim
    Sucking gas and hauling ass
    Mar 2010
    Clarksville, TN
    Not sure who is up your way but Johnny @ Big A does good work.
    423-745-9667
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    You have a P.M.
    SAMSPARTS.COM
    Hoodys and swim trunks Elkidminoltu's Avatar
    Waterford, MI
    Aaron, do you cut impellers too?
    Apr 2009
    se michigan
    [QUOTE=Elkidminoltu;3043225]Aaron, do you cut impellers too?[/QUOTE
    Yea no problem.
    SAMSPARTS.COM
    bilge rat jett's Avatar
    toledo ohio
    If the Adrian boys are to busy with there day job's I can help you out
    John
    Jet Connection
    419 473 boat
    P.S Hey Aaron how u guys been hope all is well.
    JET CONNECTION PERFORMANCE MARINE
