wriedt v drive
Results 1 to 5 of 5
wriedt v drive
    Jul 2011
    kalamazoo
    Default wriedt v drive
    i am selling my 1968 wriedt vdrive i have a ton of money in the the whole thing the motor has issues but you can hear it run comes with a 1150 dominator it is a full roller motor it is a project that is mostly done any way give me a call for details would like to offer it here first my loss your gain 4000.00 269-327-6411 thanks alan
ID:	527546   Click image for larger version.
ID:	527554   Click image for larger version.
ID:	527562   Click image for larger version.
ID:	527570   Click image for larger version.
    Surprise, AZ
    So all we know it's it has a 1150 dominator and some upswept drag headers. More details...
    Sent from my VS980 4G using Tapatalk
    Surprise, AZ
    Is the huge stainless panel on the dash covering holes?
    Jul 2011
    kalamazoo
    the panel is not covering holes just seen a boat dash like that and thought it was cool the motor has a full forged rotating assy. with scat h beams the motor has a clay smith billet roller cam howards roller rockers stud girdles studded billet four bolt main gm forged crank crower severe duty high pressure pin oilers lifters 9way cloyes timing set msd 6al msd pro billet dist psi valve springs melling high volume oil pump dooley oil pan gm 990 heads 2.25 stainless valves howards push rods theres more i am forgetting but you can call for details i have more money in the engine than i am selling the whole boat for the pistons need replacing you can run it but they need replaced i looked at them thru a bore scope the bores are fine the motor doesnt have 2 hrs on it ren lean and hurt the piston tops anyway give me a call for info 269-327-6411
    Jul 2011
    kalamazoo
    Default offer
    somebody make me a offer its a steal at this price need to sell to fund another project
