decal removal ??
Results 1 to 13 of 13
decal removal ??
    Joe Michigan-checkie michigan-checkie's Avatar
    Sep 2008
    Default decal removal ??
    I be needing some help.
    I have a checkmate pulse 186 and need to replace the decals on the side fiberglass, they are peeling along the edges.
    I have the new decals, just need to know the easiest way to remove the old ones...thanks Joe
    MI
    Heat gun and a Eraser wheel.
    oldsmopile equipped
    Lake Lansing MI.
    like rat said, heat gun, but I have used plastic razor blades. It has worked for me, I guess it depends on how long they have baked on from the sun?
    Senior Member The Violater's Avatar
    Definately heat gun if you have one. A hair drier and a razer blade will work also. They sell spray trim adhesive remover at all the parts stores to take the old glue off also. When you put the new one on, put some dish detergent in water, mix it up to a light lather, apply it to the side of the boat, you can slide the new decal around and not phuk it up............. Soap dries ........ welluh !!!!!!!! Done perfectly with no air bubbles !!!!!!!
    / The Few The Proud TheBlown
    Senior Member badnews's Avatar
    dont forget stickey side down
    "BadNews always travels fast"
    New here Beer:30's Avatar
    Bakersfield, CA
    Heat gun (carefully!) to remove the bulk. I use GooGone to remove the residue and also to soften the bulk unit prior to removal. That stuff works wonders and is not harmful to pretty much everything.
    If you go that route, don't mistakingly get GoofOFF. That stuff pretty harsh.
    heat gun and salad oil works great....
    heat gun, plastic razor blade and wd40 will alsodissolve a lot of the adhesives.
    Senior Member harley222's Avatar
    Sep 2009
    Default yep
    i used to work for a graphic design company doing vinyl graphics and the heat gun will work great but be careful with the eraser cuz it might dull the finish or burn it. good luck guy...
    Sep 2008
    Thanks for all the feedback, I wanted to dot my i's and cross my T's before doing it.
    Don't want to gouge the fiberglass wit' a rusty ol' razor!!
    Sep 2008
    Quote Originally Posted by badnews View Post
    LOL!! its that how they go??!! Sweet Thanks!!
    Sep 2008
    Quote Originally Posted by Adam View Post
    Decals are original, 1995, but I'm only the second owner. The original owner only used it two seasons, and his daughter one season, then it went into indoor storage till I found it at a local dealer. I've had it since '04, i think!
    Senior Member R/C-PILOT's Avatar
    Sugar Grove, Illinois
    Quote Originally Posted by michigan-checkie View Post
    Have someone else do it
    R/C
    NRA Life Member...
