my big ford motor...
Results 1 to 14 of 14
    Senior Member harley222's Avatar
    Sep 2009
    Default my big ford motor...
    ok guys i have had alot of questions on my " BIG MONSTER"...well i didnt do much of the foot work a good friend did all i did was dish out money and do some wrenching...lol well heres most of the specs i have and can get any more if anyone wants to know....
    FORD 528ci
    BLOCK- 1970 dove A casting bored .060, decked to 10.300 and lined honed.
    CRANK- 4.300 stroke, 4340 forged scat unit.
    RODS- 6.800 long oliver billet.
    PISTONS- 4.420 bore custom domed with light weight pins, 13.5:1 compression.
    BALANCER- ATI light weight alum super damper.
    RINGS- victor plasma moly.
    BEARINGS- clevite bearings.
    GIRDLE- canton.
    HEADS- TFS A460 heads, full port job.
    VALVES- stainless steal.
    ROCKER AND HEAD STUDS- ARP.
    CAM DRIVE- Danny Bee belt drive.
    CAM SPEC- [email protected] .050 I&E and .800+lift on a 112CL
    CAM- custon solid roller, comp cam.
    LIFTERS- comp cam.
    ROCKERS- comp cam.
    INTAKE- A460 gasket matched.
    CARB- quick fuel 1250 DOM with all the bells and whistles...
    on the DYNO the motor made 887hp @ 7000rpm and 725ft/lb @5900rpm...
    with some more tuning i hope to break 900hp and a crap ton more torque....This build was matched from a ford guys build a friend of a friend did and he ran mid to high 8's on the track... well here are a few pics...
ID:	76387   Click image for larger version.
ID:	76388   Click image for larger version.
ID:	76389   Click image for larger version.
ID:	76390   Click image for larger version.
    Senior Member blown86hallet's Avatar
    Belleville
    Quote Originally Posted by harley222 View Post
    FORD 528ci
    RODS- 6.800 long oliver aluminum.
    GIRDLE- canton.
    LIFTERS- comp cam.
    ROCKERS- comp cam.
    I HATE FORD'S>>>> THEY SUCK!!!! kidding
    Why aluminum rods in a lake boat engine, or is this engine a 1/4 mile girl?
    Sep 2009
    well i wanted it as light as i could get it and like i said this was a "copy" build and thats what the guy used, and he did use it for the strip ...
    Another Ford that was just built:
    http://www.performanceboats.com//showthread.php?t=64001
    You said you have a bunch of questions in your first post, what are they. Are you trying to figure out how to get an extra 13 hp to top 900?
    S CP
    Big Inch Ford lover
    Sep 2009
    S CP
    Big Inch Ford lover
    no i didnt have questions a few guys had them for me lol...but the motor is gunna get a different intake and a few different things and i hope to reach 900hp..
    What intake are you going to ?
    What oil did it get dyno'ed with ?
    S CP
    Jon
    Harley, I didn't know oliver made aluminum rods....
    Sep 2009
    there billet not alum...
    Curious if you have the flow numbers on your heads ?
    Your engine made 1.68 hp/cu. in which is damn good my 565 w/a-460's made 1.65 hp/cu. in with 12:1 compression
    S CP
    Sep 2009
    i dont but i can find out...
    Sep 2009
    S CP
    here ya go CP.....
    They have received only a bowl blend and gasket match and flow over 400 cfm @ 28” @ .800 on the intake and over 290 cfm @ 28” at .800 on the exhaust with some very impressive mid flows.
    Valves – Stainless Steel, 2.30 intake and 1.88 exhaust
    Springs – 1.625 diameter, 2.0 installed height and provide 300# pressure on seat
    Retainers – 10 Degree Titanium
    Rocker and Head Studs – ARP
    Guide Plates – TFS
    also not sure on the intake yet still have awhile before im gunna put it in a boat...and valvoline straight 50w. and pending on funds i mite change sum things and put a blower on it...
    Mr. Potato Head
    IN DA U.P. EH
    Nice mill Harley. What kind of fuel you running in it?
    76 COLE TR2
    Sep 2009
    Race gas, no allky...sorry guys lol but i think in gunna go with a blower set up so some things are gunna change a bit...i thought about E85 but i just dont know anything about it but im gunna do my home work a bit before i rule it out.. thanks tony
    Mr. Potato Head
    IN DA U.P. EH
    I`d go Alky, but what the hell I`m addicted I love the stuff, you have plenty of compresion for it.
    76 COLE TR2
