Jet boat shops
Results 1 to 12 of 12
Jet boat shops
    Mar 2010
    Default Jet boat shops
    Hello all, another question for everyone ..I was wondering if there is any shops or individuals that do rigging work and specifically for jets that you would recommend? I'm in the metro detroit area but willing to travel if need be, thanks.
    Senior Member Wildfire's Avatar
    Aaron Rogers and Dave Randolph are in Adrain. You can connect with them on " Samsparts.com ". I've never heard anything bad about their work and their stuff runs good. Chet
    1992 Stealth Edge
    468 BBC 670hp-dyno
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    Quote Originally Posted by Wildfire View Post
    Thank's Chet. If you would like to talk to us or come check our stuff out get a hold of us, we would be glad to help.
    Mar 2010
    Thanks guys, will definetly be in touch shortly..
    Senior Member 65BEAVER's Avatar
    Nov 2008
    livonia mi
    Default boat shop
    I spoke with these guys a few weeks ago having problems getting my pump apart. They were very helpfull and more than willing to help out anyway they can on my project. I haven't spent a dollar with them but will be doing buisness with them soon. Good luck.
    bilge rat jett's Avatar
    toledo ohio
    Hello 28 years in the jet biz 419 473 boat 2628 toledo
    JET CONNECTION PERFORMANCE MARINE
    Senior Member Bottoms Up's Avatar
    Default If it was
    Me I would talk To Dave and Aaron.
    toledo ohio
    Dave and Aaron are great guys ....I help them out when ever I can,just ask them......see ya on the pond
    Green Bay Wi,USA
    George Pataki -ARS Marine
    Apr 2009
    se michigan
    Quote Originally Posted by jett View Post
    Thank's John, you have helped us out , and we will continue to work together making some of the baddest boats in this part of the country!!
    Quote Originally Posted by hot-rod 21 View Post
    You guys Do run Hard, and build very nice machines.
    Senior Member spectralen's Avatar
    Aug 2009
    Mi.
    Stay away from S&A Auto Service and Marine in Allen Park. They claim to know performance and jet pump work. That's when they built my 460 and showed me how it performs with a Dyno run.
    First problem I saw was that my new engine was hanging from a cherry picker and resting on my newly purchased $500 Dooley oil pan with a battery and gas can hooked up. And I do believe there was NO WATER going to it.
    After the engine was installed back in the boat, that's when I found that they put in the wrong size piston rings in one of the cylinders, which meant burning a quart of oil every time out.
    Then the engine threw a rod.
