Back in the day....
Results 1 to 6 of 6
Back in the day....
    Bah... HST4ME's Avatar
    Michigan
    Default Back in the day....
    there was stuff like this...190? something
    Aluminum Block
    5 inch bore with a 6 inch stroke
    ROLLER lifters
    Gear drive, twin cam
    Two plugs per cylinder..
    crash box
    See that flywheel? That's how real men started their boat, by hand!
    Senior Member Wildfire's Avatar
    And I thought I was old. Lynn, what cave did you find that in? Chet
    1992 Stealth Edge
    468 BBC 670hp-dyno
    deckboat owner rschap1's Avatar
    Lowell MI
    Default The Gilmore
    I enjoy looking back at what was accomplished way back when...
    The Gilmore Museum in Hickory Corners, MI has some incredible stuff.
    I enjoyed the Henry Ford when I visitted with my kids school clas.
    I had seen an early 1900's rig that blew my mind when I was a young teenager.
    Said it was ran at Daytona right around 1900.
    BIG open crancase 4 banger with coffee can size slugs.
    Multiple glass oil dups with felt drippers leading to bearing/babbett surfaces.
    Mechanic rode along and serviced it while setting speed records.
    Hanging out over the motor while doing 115+ mph (if I remember right)
    Everything was exposed. Cam out the side of the motor, no oil pan. Just a drip tray trying to channel excess drippings behind the rear of the car.
    High tech frame material...OAK!!!
    Had a huge tractor style flywheel driving leather belt !!
    I could not believe anyone would be brave enough to go 30 let alone over 100 on/in it!!
    WAY back when!
    Senior Member ccrick's Avatar
    Sterling Hgts. Michigan
    Any manufacture stampings on it? I like the roller cam. Flywheel looks like about 80lbs. would idle at 300 rpms. I remember at a antique boat show at Marine city they had a bunch of really old motors they would run. Pretty cool. Carbs with wicks? Yep
    1980 Hydrostream Viking
    1978 150 Black Max
    *Life begins on the pad*
    Senior Member racer's Avatar
    Dec 2010
    ya gonna try and make a stationary runner out of it or just a looky lou to look at?? cool piece! did ya get the mag/ignition with it?
    Michigan
    It was mostly all there with the mag and starting ignition. The oiling system was broken by the person who delivered it. It has a Detroit Lubricator set up like a dry sump system. The motor is worth a considerable amount of loot, so after it is up and running again whomever brings the checkbook and provides a good home will get it.
