What a sweet sweet smell it is..
Results 1 to 6 of 6
    Senior Member racer's Avatar
    Dec 2010
    Default What a sweet sweet smell it is..
    Pulled the boat out of the winter storage and cracked her off today.. going to run the valves tommarow and chang the oil,ect.. got the fever bad!!! on a bad note callled my 100LL supplier and they have changed owners and its also up to 7+ dollars a gallon!! man this is gonna hurt.... if i can get a few health issues behind me im hoping to run her down south next month with my youngest son on his spring break..maybe somewere in ga or south carolina..got my prop back yesterday so were getting close.anyone else got the fever????
    Senior Member Wildfire's Avatar
    Convert her over to E 85. Makes more H P and costs less. Uses about 30% more but it's still cheaper. That's what I'm planning on doing to Wildfire if I don't sell her. Looking forward to seeing you and yours at Wamplers lake in May. Chet
    1992 Stealth Edge
    468 BBC 670hp-dyno
    Dec 2010
    Quote Originally Posted by Wildfire View Post
    im wanting to go blown so im not going to spend any $ on this setup..these carbs wouldnt make good e85 carbs and the blown e85 carbs wont work on this setup..kinda in a hard spot..going to try to look at some homade boosters and running 93..not sure yet. we mixed it last yr and that seemed to work ok.. pull a bit of timing out of her and put more start retard as the dist we run is fixed. lol had all the nieghbors looking around yesterday!!!
    Holly smokes we are still under $ 5.00 for 100LL
    Dec 2010
    well were are you located?? im i coming past your area on my way up this yr?? i will bring 2 55 gal drums!! $7.18 a gallon as of fri down here.
    1 mile west of IL. Rt 47 on the North side of IL. Rt 30 The Phillips 66 dealer, let me know if your in the area.
