Some thing to read.
Results 1 to 1 of 1
Some thing to read.
    Member Katanna's Avatar
    Jun 2010
    Howell Mi.
    Default Some thing to read.
    Well not much is being posted so heres some info on what going on in my (boating world).
    460 ford has been running great all season with a couple of small issues.
    1. Couldnt stop the oil from spraying out of the breather after hard runs. Ended up moving my breather from the rear to the front of the valve cover and running the pcv hose in the rear valve cover hole to the carb base. Works much better and only get a slight couple of drops on the valve cover. Will run a hose to the exhaust this winter.
    2. Having trouble keeping the exhaust log bolts tight and sealed. Waiting on new gaskets from JBP and will use locking nuts.
    3. Also waiting on a drop snoot to loosen the hull up a little.
