New Jet Boat Owner Looking for help
    Jun 2012
    Default New Jet Boat Owner Looking for help
    Hello to all, my name is Sam and I live in east TN. My girlfriend recently inherited a Jet boat when her dad passed away and we finally found time and a way to go get it from Knoxville. I am a fisherman and this is not exactly the jet boat I have been dreaming about, but itís a free boat and we are going to try and at least take it out a few times and play with it to see how we like it. My problem is that I donít know anything about jet boats. The boat is an 82 model I think and is made by Sundancer. It has a 454 Big Block with a marine jet drive (something on the back of the engine says Glenwood, maybe this is a brand name of the jet drive?) This thing looks mean and fast. He used it regularly up until he got sick and it hasnít seen the water in about 7-9 years. It has been started from time to time, but nothing at all done to it in the last 4 years. I think I can handle reviving the Big Block, but all this jet stuff is new to me. My biggest worry is how does this thing cool the Big Block? I see no radiator, so I am pretty sure that the jet drive somehow pumps water through the engine to cool it. I am pretty sure I can start this thing in my driveway as long as I just let it idle and donít give it heck. Problem is that I know there needs to be water hooked up to it somehow, but I canít figure out how to do that. Then when I do get it started and running again I need to figure out what all a jet requires to run. Does it need to be greased each time? (seems like I have heard something about doing that) What kind of maintenance things should I do to keep the pump in good shape?
    Like I said I am new to this and am really just looking for advice on how to go about getting this thing running without doing any damage to the engine or the pump. Should I unhook the drive line to the pump while messing with the engine in my driveway? Can I just hook a garden hose up to the engine and let her rip? Maybe some of you jet boat owners can give me some pointers. Any info would be greatly appreciated! Really donít want to screw this thing up because of lack of knowledge. Also does anyone know anything else about this boat just from looking at it? Like what itís called, what do you call this type of boat? Does anyone on here have a boat similar to this that lives here in east TN, Boone Lake is where we will be running this thing if we ever get it going. Here are some pics.
    Jun 2012
    Yes you do not want to run the pump out of water its the quickest way to do damage. There should be a hose coming from the pump to the motor that suplies water to the engine you can dissconect the pump from the engine and the water line and run the garden hose at full balst but i wouldnt be revving it up alot the pump puduces a lot of pressuer to push the water trough and ur garden hose dosnt so just be carful there. It looks like a panther pump but i could be wrong and as far as the glenwood badges thats the company that makes the parts like the bellhousing and exahust componets for jet boats. im more familar with berkey pumps. but all pumps require maitnence but not nerly as much as an out drive if you snap some more pics of the pump inside the baot some one might be able to identify it better and have tips on what you need to do. There are alot of helpful people on this fourm so just keep checking back.. Hope some of this helps
    Jun 2012
    Here are some more pics that may help tell some things about this boat:
    Trying to figure out the fuel system. Does this thing auto select the tank or do you have to manually do it with a switch?
    Found this switch beside the ignition (might be for fuel select or could be for the bilge pump?) anyone know?
    Looks like this thing is a TX-19 (which I don't know what that is exactly, but I take it that is the model?)
    Can anyone tell me more info on this boat with the help of the HID?
    Any help would be greatly appreciated!!!
    Sam
    You have a Berkeley 12JC Pump and I believe the "A" is in reference to the impeller size.
    There are two 1/8" pipe plugs in the bowl of the pump. The are on the outside of the boat located at about 10 and 2 o'clock. You need to remove both plugs and the take a squeeze bottle and hold it against one of the openings and fill it until it comes out the other opening. Then replace the plugs. I use a heavy gear oil in mine. The are also two u-joints inside the boat that make up your drive line between the engine and jet. Those should both be grease as well. You may have to rotate the engine to get the grease zerts into an accessible position. With a hand grease gun I would say roughly 3-4 pumps per u-joint should be sufficient. Those items will allow you to run the jet in your drive way with out damaging it. I still wouldn't run it at much more then idle for extended periods of time. I see a garden hose in the boat so I am assuming you found were to hook that up to cool the engine.
    I use cpperformance for jet parts and tech support when I am in a hurry. The website is cpperformance.com. The number is 800-225-9871 Others may know of different places also. They also have breakdowns of your pump online. As for the wiring, thats anyones guess.
    Hopefully this helps.
    Brian.
