magneto dist
Results 1 to 12 of 12
magneto dist
    Default magneto dist
    I have a Vertex Magneto dist on a 454 chevy motor. the motor runs rough at idle, does any one know what i should checking for? what is gap setting on dist, and plugs? Joe
    Senior Member BlownSST's Avatar
    Are you running gas or alky?? they don't usually run mags on gas, better with alky. Are you running blown or asperated??
    gas, asperated, it seems to run good at high speed, but at idle it stalls and acts like it ran out of gas?
    Cantard 71hallett's Avatar
    snow bank
    I gap mine at 20
    plugs? at 20
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Quote Originally Posted by joe wojtowicz View Post
    Do you know Dyno Don? He run asp. with a mag, he may be able to help you out.
    yes i do thanks
    Michigan
    yes i do thanks
    I have his number if you need it.
    yes i need it pm me
    Michigan
    Sent
    Hey Joe you get if figured out?? if not bring it along with some new points, some one will get be able to get you running.
    ok thanks
