Question about speed coat
Results 1 to 11 of 11
    oldsmopile equipped
    Lake Lansing MI.
    Default Question about speed coat
    I was just wondering if there is a big difference between speed coat or john deere slip plate. I have a can of dry moly lubricant "speed coat" that has molybenum disulfide?? made by advance aerosol but its just a spray can and I will need more for the bottom of my boat, I see that's the stuff that what rex sells has in it. the john deere stuff just says graphite dry film lubricant but I have heard that some people use it. I'm sure I should just get the real stuff but if there's not any difference than I can just go down the road and get it, what do you guys think?
    Breathing Diesel Shotgun19's Avatar
    Michigan
    You can use the stuff from john deere store with no problem!! And save a few bucks. TSC has it also
    Senior Member tx19condor's Avatar
    my jet boat guru told me to use the stuff your talking about on mine, says it works just as good as the name brand stuff, he hasnt steered me wrong yet!
    same thing, i've used both, and its easier to go to the j.d. dealer and get it.it shoots kinda dry so use some worn out scotch brite to knock off the overspray.
    use a respirator, speedcoat is some nasty shit and makes for some nasty ass boogers if ya don't
    oldsmopile equipped
    Lake Lansing MI.
    thanks for the quick replies, sounds good! this way I can spray it this weekend, should I just spray over the 1200 grit wet sanding or should I sand it with something a little stronger? oh the bottom is imron.
    The Earth
    Blog Entries
    24
    Molybdenum disulfide is much more durable than graphite in the compound supplied by Lubribond A (speed coat). It's much more expensive as a result. It has a wide range of uses including inside engines and weaponry. Its used in greases, nylon, nylatron, and teflon just to name a few. It is not graphite.
    Has anyone done any true testing with and without the speed coat??
    I have heard that making the bottom excessively smooth creates a "sticky" bottom and actually causes more friction.
    One example of this is the lower units on race boats, they are left with a "rough" finish to create aeration and therefore less grab in the water.
    Can't say I have seen any true testing or proof, but it kinda makes sense.
    Hard Core Member
    Speed coat doesn't do anything. I'm sure I'll get beat up for saying it but I have never seen it demonstrated that it increases speed. The shape of the bottom of the boat is 99% of it, and the texture of the surface is the other 1%. The varying coefficient of friction of the surface finish at a given surface roughness is just not relevant.
    DJ
    Green Bay Wi,USA
    I wonder if the U.S. Navy did research into this? I bet they did. I put graphite spray on my rideplate, speedcoat on the hull. Cheap enough, does it help?, I don't know. the ride plate seems to have bottom side wear and with graphite it is less noticeable.
    Senior Member flattie's Avatar
    Menominee mi
    I put powdered graphite in with my paint on the bottom of my boat. Stuff is like sanding concrete. I picked up 3mph
    A legend to the DNR vdrive502's Avatar
    Lake Hallie,WI
    Flattie all that work for 3mph I think it is easier to just change the blower pulley and get that.
