flame arrester?
Results 1 to 7 of 7
flame arrester?
    oldsmopile equipped
    Lake Lansing MI.
    Default flame arrester?
    I need to start looking for a single carb scoop,may be a stainless bassett. Is there any law in MI. about running a arrester or can I use a K&N in it? its an opened engine bay.
    Breathing Diesel Shotgun19's Avatar
    Michigan
    Running a air cleaner, that just restricts air flow.
    oldsmopile equipped
    Lake Lansing MI.
    Its protection from ducks and swans
    o.k than if I just run an open carb will the dnr or sheriff be fine with it? or is it a lake by lake thing. I just don't care to get hassled with when I get on the water.
    Michigan
    I have never run a air cleaner, always have had a scoop. Im sure you should have a flame arrester but like I said it just restricts air flow. If the focker want to put his arm in there to check it is just a good reason to break it off
    What about running a flame arrester in Ohio?
    Quote Originally Posted by Shotgun19 View Post
    Ooohh assault that work every time
    Michigan
    You drunk posting again?
