new comer needs some help
Results 1 to 6 of 6
    Jul 2013
    Default new comer needs some help
    hey guys i took a boat in on trade last year supposedly the starter was but but come to find the air cleaner had been left un coverd and water got in the pistons and seized the motor the boat needs some help and i would like to do it as winter project but i have no idea where to start its titled as a Californian 1973 needs fiberglass work on the front end its chipping needs a floor and has some damage on the underside it did float when i got it but had some leaks iv pulled the motor and pump and covered it up until now thanks for all the help and im in holdenville
    Senior Member hillbilly68's Avatar
    Searcy, AR.
    Quote Originally Posted by HARDWICK09 View Post
    post some pics so everyone can see what you have.......water in the pistons is not good....
    77 Daytona Eliminator FORD 557
    IF IT AINT STROKED IT AINT A MOTOR
    Okmulgee Okla.
    Welcome to the insanity. Like David said, post some pics so we can see what you have to work with. Would like to see where it needs fiberglass work for sure, sense that is the back bone of what you are working with.
    What motor is it setup with or for, Performance is costly, and is measured in cubic dollars $$$$$. The people on this web site are some of the best at figuring out what you will need.
    Do a search and see what you can pull up from past post and start learning. I'm in Okmulgee, if you are ever in this part of Okla. let me know. Or PM me your phone number. Oh, by the way my name is Don.
    well the block is GM any ways
    IS UNDER FIRE
    Oklahoma Hot Boat Assn BeerBudget212's Avatar
    Apr 2014
    Quote Originally Posted by HARDWICK09:3389545
    Did we talk via text msg or fb here a while back? Seems like I remember something like this
    Jul 2013
    thanks for all the replies guys and yea beerbudeget we did but some things came up and it got put on the back burner its set up for a BBF which im not a fan of if i build it id like to go to a BBC its got a Jacuzzi yj that needs rebuilt and a new impeller as far as the motor it probably would have been ok but the bearing on the shaft that comes off the flywheel was seized is what the problem was come to find out ill try and get some pics today sometime
    Jul 2013
    well not gonna have time to bulid it this winter work is stacking up so it needs to go 1000 obo text 405-973-6292 for pics or info has a clean title just needs switched over trailer is solid located in holdenville ok
