[Question] Stringer placement
Stringer placement
    Jun 2019
    Default Stringer placement
    What material should be used to place the stringers prior to glass work
    Peoria, AZ
    There are betting things to use than what I have used, but I used thick wetted mat to bed my stringers into.
    Paul
    Member John Thompson's Avatar
    Apr 2017
    Bangor Maine USA
    This is going to raise a lot of hell but I am planning to bed stringers with 5200, before glassing. This is where I got the idea. I don't have a name but the poster seems experienced, he's all over this other forum.
    https://www.boatdesign.net/threads/p...s-hulls.59863/
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    100 ways to skin a cat... I used polyester on my build because that is what I knew, tore long strips of matt and wetted out two layers and sat the stringers on it, if you frey the strips on both sides you wont get a hard line of glass. Put a little weight on top, don't go crazy with the weight and push all the resin out. Floors and stringers were ruffed up with 24 or 36 grit to make sure we had a good mechanical bond as well.
