Paint & Detailing questions.... - Page 20
Page 20 of 20 FirstFirst ... 10 17 18 19 20
Results 267 to 272 of 272
  1. #267
    Senior Member Billy-B's Avatar
    Alta Loma, Ca
    Quote Originally Posted by phughes SS-13 View Post
    It appears the gel is not blistering. What youseinthe pics is actuallpaichipping. Under the paint and primer is a different color gelcoat. Back to the sander for me.
    Remember....keep the sander flat. No rolling up on the side / edge. It will show. Good luck. And keep the sander moving.
    N.R.K.A. CEO of the Needles River K Association.....The largest "K" boat assoc in the WORLD. 30 boats strong & growing.
    And the #1 backer of " EASON " for President.
    "Blown Gas Flats to the ramp!" - Chris Blevens
    Senior Member wayne421's Avatar
    Apr 2013
    americus ga
    hey billy what do you think about dupont imron for my hondo runner bottom will it flex with the fiberglass
  4. #269
    Alta Loma, Ca
    Quote Originally Posted by wayne421 View Post
    It will work out just fine. Very durable.
    Apr 2013
    americus ga
    Thanks billy
  7. #271
    Dec 2012
    Hey Billy, I'm in the middle of a resto on my 70 Hondo flat. The deck is all spider webbed and I sanded it down to the gel coat and it's also cracked. I'm guessing I have to take it down to the glass. What material should I use on the deck? I'm using West System epoxy
  8. #272
    Alta Loma, Ca
    Quote Originally Posted by nevada hondo View Post
    So sorry for the late response. Nobody had been asking any ??? for so long I hadn't checked in. I'm sure your past the point of needing my help. But by chance your not here is what I do. I ship the boat to my glass guy....lol..The gel does need to come off all the way down to the glass. Chances are the glass will have those cracks as well. Glass / deck then gets grinded or sanded & a new layer of glass put on it. Once all the steps are taken to smooth out the new glass you can prime in epoxy or polyester primer & your ready for paint. If you don't remove all the cracked area down to the glass your wasting your time. Those cracks will reappear again...TRUST ME. Good luck. If you have any questions at all, please feel free to call the shop. I will try & help you out...909-982-8555.
