Gaffrig gauges GPS Speedo RPM oil water volts fuel boost trim
Results 1 to 1 of 1
    May 2011
    Default Gaffrig gauges GPS Speedo RPM oil water volts fuel boost trim
    Gaffrig gauges I pulled out of my boat to put larger ones in. They functioned just fine when I removed them which is why I saved them. Just cleaning out the garage. All the bezels, brackets, nuts and lock washers are included. The only thing missing is the bracket for the RPM gauge. They are easy to get or even make
    3 3/8" 160 mph GPS Speedo w/ adapter bezel wiring & switch
    3 3/8" 8000RPM
    2 1/8"
    0-80 Oil
    100-240 water temp
    trim
    30-20 boost
    10-16volts
    fuel level
    The oil is a bit discolored.
    They obviously don't belong in something super nice but maybe someone can use them in a project or budget build.
    I won't separate them.
    $200 obo plus shipping
    Call or text only
    661-313-2085
    Jason
ID:	923001   Click image for larger version.
ID:	923049   Click image for larger version.
