[SOLD] DIRT CHEAP Fuel and ignition EFI Management Systems + Spares F.A.S.T.
Results 1 to 2 of 2
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default DIRT CHEAP Fuel and ignition EFI Management Systems + Spares F.A.S.T.
    SOLD
    This is dirt cheap ! Nearly all of it brand new.
    EFI/Ignition Bundle F.A.S.T. XFI 2.0 Fuel and XIM Ignition Systems + Spares
    Only requires a download to be the latest 2.05 version.
    XFI box was my race spare. New dual injector driver motherboard installed from F.A.S.T. Has datalogging option. Pic details attached.
    NEW: XFI main harness, V-8 injector harness, 5 datalog sensor harnesses, Wideband harness, Calport harness.
    XIM Ignition 301311 Brand New in Box with harness.
    8 Brand New XR-1A coils mounted on a bracket. Bracket attaches to engine block mount holes. MSD superconductor 8.5mm wires with ends for the coils. 2 Factory ls coil harnesses with XR-1A coil connections. 2 60 amp relays if you want to run battery voltage directly to the coils. 1 spare relay.
    CO2 boost control valve wired in.
    Sensors brand new. Some installed idled but not run: 5 bar MAP, water temp, IAC, TPS, 4 Wide band O2 (2 new in box) several typical fuel and oil PSI one of them 0-500. Spare inductive crank trigger pick up sensors. More also see pics.
    Everything Listed Above and In Pics $2,000 SHIPPED or pick up Miami, FL 918 two six nine 8084
    Also Available For Sale : Ask for pics
    These parts are NEW were installed started and idled.
    8 NEW precision Turbo 225 lb/hr low impedence injectors $900
    Custom billet HE GM V-8 Cam Sync with slip collar and composite gear $175
    NEW Custom heavy wall 304 Stainless turbo Headers SBC NEW a work of art $1800
    Belt Drive Enderle 990 with electric prime pump and Magnaflow bypass regulator. $500
    NEW 3GPM manual injector system CO2 operated on off valve distribution block hoses and Gorr nozzles. Plumbed into Wilson elbow base. Elbow not included. $200
    NEW System 1 EFI fuel filter and mount. $180
    NEW Procharger Red Race BOV $350
    NEW 16 Volt Racing Battery and Alternator $400
ID:	1032551   Click image for larger version.
ID:	1032553   Click image for larger version.
ID:	1032555   Click image for larger version.
ID:	1032557   Click image for larger version.
ID:	1032561   Click image for larger version.
ID:	1032563   Click image for larger version.
ID:	1032565   Click image for larger version.
ID:	1032567   Click image for larger version.
Name:	wires and relays.jpg
    QE 439 Twin Turbo
    New Port Richey, FL
    Bump priced Dirt Cheap
    QE 439 Twin Turbo
