BBC 427 Pro Topline heads V-Drive oil pan PLUS TONS MORE
Results 1 to 10 of 10
    V-Drive 4 ever Billdoe's Avatar
    Greenwood , Calif
    Default BBC 427 Pro Topline heads V-Drive oil pan PLUS TONS MORE
    buddy is selling everything he has .. the engine is a 427 with Pro Topline heads with roller rockers and i believe is a roller cam .. looking to get 700 for pair of heads Square prt with Fresh rebuild on them from Motor Machine in Carmicheal Calif .. set up for 700 lift roller cam ..and 500 for the short block . also has a Milodon V-Drive oil pan complete with windage tray and pickup tube askin 200 .. Tons of parts . Boat was a 77 Riviera Gran National v-drive pretty much everything in boat is being listed for sale and also have TONS of other parts i will be listing so check my other listing for lots of Parts n Pieces . im on dial up so email me at [email protected] for pics
    ENGINE HEADS AND STUFF ARE SOLD
    Senior Member dragstr19's Avatar
    Chandler AZ
    P M sent
    Future GN Racer! fdlock890's Avatar
    Las Vegas
    PM sent
    Senior Member blown86hallet's Avatar
    Belleville
    Pm sent>>>
    Greenwood , Calif
    Pan is Sold Thanks Hondo Jim ...
    Heads i have a deal pending on will update later ...
    will have more info on the block when i return this afternoon
    Greenwood , Calif
    head are still for sale .. they are a Casst iron set of Pro Toplines with 320 cc ports and i belive are 2.25 valves maybe 2.30 not sure on valve size but they are stamped on the side 320 so im assuming thats the port cc's ... they will come with Blue anodized Roller Rockers and a set of ARP Head bolts and i also have a set of 3/8th push rods i will throw in too 700.00 plus shipping ....
    Block is most likely sold to a friend its a 1975 427 4bolt out of a big truck with a solid lifter cam NOT Roller has 12to1 comp pistons in it and a Gear Driving timing set and a solid lifter cam around a 650 lift .. asking 500 for it
    369 is offline
    interested in the block if your deal falls through... i send ya a PM
    Greenwood , Calif
    block Casting # is 3999289 and casting date is B 10 75 so looks like it was a feb 10th 1975 engine block but it shows its a 454 block but engine builder said it was a 427 so not sure whats going on . it is a 4 bolt block tho .. it is still available but might have someone coming to get it but not sure yet
    Sacramento Ca.
    how much power was the entire combo putting out? id be interested in the block for sure possibly all of it.
    whats the story on the motor... why the part out?
    Greenwood , Calif
    not exactly sure on the power motor was putting out . figured it was around a 500-550hp setup .. the engine had to be torn down cause the boat was wrecked and sank so had to tear it down to clean it up and make sure it was still in good shape .. everything cleaned up good so since it was apart figured part it out .. can do a package deal heads and complete short block for 1250.00 thats timing cover harmonic balancer everything cept motor plates and oil pan .. Bill .. this will be sold by thursday someone is coming up to pick it up supposeably so let me know 530-333-1047 Bill
