#333 Turbine Whitewater Raceboat
Results 1 to 13 of 13
    Senior Member ravencrew's Avatar
    Default #333 Turbine Whitewater Raceboat
    Team Burning Desire's Turbine powered jetboat
    http://
    Senior Member KKernen's Avatar
    Walled Lake
    Default note from kevin
    whats the MPH on this thing.....
    doe's it just burn the impeller with and that thrust out of the hole?
    or will it stay hooked?, what kind of pump and bowl is that?
    Thanks for info
    Quote Originally Posted by KKernen View Post
    Thanks for info
    I think the pump is an AT I don't know what type of impeller other than it's stainless steel. The boat does stay hooked up throughout the course. The speed was clocked during testing at the Klamath River Bridge by a CHP at 135 mph.
    Driver 78CoLeBBF's Avatar
    Golden Shores,AZ
    didnt it get run down by a bbf last race
    Morgan Hill
    Quote Originally Posted by 78CoLeBBF View Post
    Didn't neccissarily get run down, but for the first race for this boat it did extremely well, the Spencer King team was really consistant and made the most of Tim's unfortunate DNF on one leg due to spin out that broke some parts...If I had to lose, I would want it to be to someone who had a race like that, that Ford hauls ass...
    I'm not sure if anything in that BBF is off the shelf Ford stuff....Vey cool.
    GT
    Golden Shores,AZ
    that brings a tear to my eye and a bulge to my pants and no big hp motor is any thing other than some ones cool expensive $h!t big Ford are part Chevy/ Pontiac big hp Chevy's are half olds/Pontiac and real big big hp stuff is mopar design just my 2 cents
    ... and real big big hp stuff is mopar design just my 2 cents
    I wish I had room in my sig line.
    Curious what type turbine is in it ...... T55 ??? You'd think fuel consumption would be an issue... Awesome boat !!
    Quote Originally Posted by RetroBoats View Post
    T-58 Turbine
    All high end. Billet suction housing, looks like an AMT bowl
    B1 Racing cs19's Avatar
    whats the yellow thing on the end of the nozzle?
    B1Racing.net
  13. #12
    CS It is for helping get the hull on step earlier. As you can see these boats are set up a bit tail heavy. They call it a duck bill.
  14. #13
    Morgan Hill
    Quote Originally Posted by bottom feeder View Post
    Or a Beaver tail if your from Ore.
    GT
    GT
