Eliminator Liberty
Results 1 to 14 of 14
Eliminator Liberty
    Nov 2008
    Grand Haven
    Default Eliminator Liberty
    Name:  1 eliminator 001.jpg
    1989 eliminator liberty , i need to install new motor and give some tlc.
    Senior Member HavasuDreamin''s Avatar
    Indianapolis
    Nice looking hull. What are you putting on it for power?
    19' Eliminator Daytona
    21' Ultra LX
    Nov 2008
    Grand Haven
    Default outboard power
    it had a johnson 200 on it but it needs a rebuild so i may but on a mercury 225. Not really sure the speeds it will run? can not find much info on this outboard hull.
    Indianapolis
    My guess is with a 225 and proper setback, you could see mid to high 70's. Jack plate and a nose cone/lwp would be necessary. Good luck.
    21' Ultra LX
    Nov 2008
    Grand Haven
    What would you recommend for setback? i have a land & sea jackplate.
    Indianapolis
    I am not extremely familiar with the hull. I know it runs well in a jet configuration when set-up properly. My guess is 6-10 inches with the bracket and another 6 inches with the jack plate. I run a 19' Daytona with 12 inches of set back. The hulls that are not notched on the running surface need setback.
    Good Luck.
    21' Ultra LX
    Senior Member 76 Bonneville's Avatar
    Valley Center Ca
    Not sure if you have any interest in these. Just scanned them from a pack of flyers that are from around 1987.
ID:	26451   Click image for larger version.
    Nov 2008
    Grand Haven
    I would love to have them i am trying to get as much info as i can get, How do get them thanks jeff
    Valley Center Ca
    Quote Originally Posted by gunner_bear View Post
    PM me with your address and I'll send you a copy.
    Mar 2011
    Default Liberty owner
    I have the same model and year. I owned it since 1995.
    "I know this boat like the back of my hand"
    Full Of It. Mandelon's Avatar
    Sandy Eggo
    Thumbs up
    Great looking hull style.
  13. #12
    Member W.O.T. Marine's Avatar
    Feb 2010
    Carlsbad
    I have one
    Its an 86' bought it a few years ago from origonal owner. Mine has a merc 150 2 LTR I think it has about 8" of set back. I tryed a 2" spacer and it helped on the top end 2 Mph but it was flexing the transom more than i liked.
    Right now i have the factory set back and engine is as high as it goes on the plate, the prop shaft is about 1.5" bellow the bottom of the hull. I have a standerd lower unit and has plent of water psi. I have tryed differnt props but a 3 blade 23pitch chopper seems to be best. Let me know if you have any questions about set up. post some more pics of yours please.
ID:	116420   Click image for larger version.
ID:	116421   Click image for larger version.
    Custom boat service and repair.
  14. #13
    Jun 2011
    Tiltonsville OH
    Cool the boat Gunner bear had i own and have owned for 2 yrs it is being redun as we speek
    i need a little info about were to hang the jack plate were can i get a ski locker for the wood floor i added a center gas tank and am looking for hydrolic steering to put on the boat and maby some new gauges and some tunes would like to chat with the guy with the blue one maby he can give me some advise on how to hang the jack plate on the back. might add a tilt helm ????
  15. #14
    Sep 2008
    Quote Originally Posted by Joshuah40 View Post
    There are two versions of the Eliminator Liberty; the 19’ that was designed for jet application and a 20’ that had a molded in splash well for outboard use. The blue Liberty posted by W.O.T. Marine appears to be the 19’ version, no splash well. Be aware, what works on the 19 may not work the same on the 20’ outboard version. There were more changes to the bottom then just adding a foot. Most all 20’ liberty OB’s, at least those built in Mira Loma had the motor bolted directly to the transom and did not use any spacers or set back. Very few had jack plates and those that did use the Land & Sea unit. I would not add anymore set back if you have the 20’model and use the land & sea jack plate; if I remember correctly it has around 5”. I never felt the jack plate was required as long as the motor was mounted at the right height from the start. The boat ran just fine with anything from 150hp to as much as 200hp. The hull is over 20’ so there are no restrictions on HP if you want to get brave and go for something with more power. The ones I drove performed great with the 150 hp motor in the standard location,no jack plate or set back. They planed quickly with no drama or prop slip and the light weight at the transom made them handle like sports cars. As for steering, you could go with a single ram hydraulic system such as IMCO, but a good Morse duel cable system should work just fine with the lower HP engines. Most ski locker doors are just plywood that was resin coated and covered with carpet. Just about any marine gauge will work; just remember to get a tachometer and trim gauge that works with the motor you install. The Liberty OB was and still is a great little family boats.
Name:	20' LIBERTY OUTBOARD.jpg
