re-use fuel/water filter separator?
Results 1 to 2 of 2
    Junior Member HydroHaulic's Avatar
    Jun 2016
    Default re-use fuel/water filter separator?
    so still working on my new to me jet boat...
    having fuel/tank/lines/pump issues... yes all of those
    so replaced all lines and fittings, new mechanical pump coming...
    trying to clean inaccessible tanks... so when i got it i sucked out all the old fuel, added seafoam and non-ethanol 90.... have run thru 40 gallons but last out lost fuel pressure and delivery..
    think the problem was the garbage pretty blue fuel lines had an inner liner which i think collapsed...replaced
    anyway main question... i am circulating the fuel thru the filter/separator back into the tank with a transfer pump.
    can i dump / dry and re-use this filter? not much debris, mostly water and old fuel settled on bottom...
    thanks in advance!
    Senior Member TexasJet's Avatar
    College Station, Texas
    If this is a fuel/water separator that came with the boat, I'd change it. They are not that expensive and you are going to a lot of trouble to fix a fuel problem. If it's a new filter you just put on you cam probably reuse it.
