Mystery throttle cable end
Results 1 to 10 of 10
    Dec 2012
    Default Mystery throttle cable end
    I am replacing the throttle cable on my 21 Daytona and I can't seem to locate a cable end that connects to the Nicson gas pedal. The old adapter has a 10/32 female thread on one end and a 5/16" hole in the other. Through all my internet research, I haven't been able to find a replacement. I'm not sure if this was a factory piece, or something homemade.
    If anyone has an idea where I might find this part or a comparable replacement, please let me know.
    Thank you
ID:	955346   Click image for larger version.
ID:	955354   Click image for larger version.
ID:	955362   Click image for larger version.
    Senior Member SPECTRA-SANGER's Avatar
    Sep 2016
    Not sure if that is Nicson stock or not but can you unscrew the adaptor on the pedal and put a ball type connector on? I have two like yours and neither have that end. Interested to see if anyone else has the same as yours.
    Senior Member bville's Avatar
    Sep 2009
    Glasgow, KY
    Quote Originally Posted by SPECTRA-SANGER View Post
    My nicson doesn't have the end the op shows.
    Quote Originally Posted by falcain View Post
    Thank you
    I think if you look around you can find a rod end that would be 10-32 thread with a 5/16 hole. Might call Rex Marine, didn't see one in their online listing, but there was something similar that might be made to work.
    Sep 2016
    Dec 2012
    Thanks for all the input guys.
    I have looked into replacing the original piece with a ball joint style, but haven't found a ball stud long enough to get the cable end to clear the slot in the pedal mount plate.
    I also considered a rod end, but can't find one with 10-32 female threads on one end and a 5/16 hole on the other. I may have to try to recreate the original piece with a scrap piece of steel or aluminium.
    Any other suggestions or ideas, please chime in.
    Apr 2010
    Rocklin, Calif.
    Could you show more pics of your peddle, I have one out of my CP that looks the same...just doesn't say Nicson
    check with mercruiser that is there piece. I have seen them before on many boats.
    Dec 2012
    I've done every google search combination I can think of to find a duplicate of this piece, but haven't been able to find another one like it. If you have any idea where I might locate one, I would greatly appreciate the advice.
    Thank you
    Dec 2012
    Well, after wasting way too much time searching for a suitable replacement for the original piece, I decided to just take an hour away from re-wiring the boat and make a replacement myself. Summer is coming quick and I have too many other things to get done on the Daytona to let this hold me up.
    I appreciate everyone's input and suggestions.
