Which Full Hydraulic Steering System do you guys recommend?
Results 1 to 11 of 11
    Dec 2017
    Default Which Full Hydraulic Steering System do you guys recommend?
    So the Twin turbo setup I am putting in my boat wont fit unless I get rid of the power steering bracket and pump.
    So I want to go Full Hydraulic Steering. Which is the best brand?
    1989 Checkmate Maxxum 229 with Bravo 1 outdrive.
    Thanks for the input.
    Jason
    Jason, Still need power steering pump for full Hydraulic steering, maybe relocate.I have had good luck with IMCO,the one in Nevada, great to work with.Which turbo setup?
    Dec 2017
    Quote Originally Posted by 1SNYDER View Post
    Well that sucks, i thought full Hydraulic eliminates the power steering pump. I called Hardin Marine and asked them too and yes you are correct. they did say Mercury Make an electric power steering i could switch over to. So i will look into that. relocating the power steering pump is going to be a huge fabrication issue for me. So i need to upgrade my steering anyways.
    I will be running an Old Gale Banks Twin turbo setup.
ID:	1006594Click image for larger version.
    Member Tahoe540's Avatar
    Jul 2016
    Sparks, NV
    Jason, I have an OMC king cobra setup and the power steering is very low. Maybe this setup will work for you and you would only need to find the bracket. Much cheaper than full hydraulic steering setup
    Dec 2017
    Quote Originally Posted by Tahoe540 View Post
    this could be an option, thanks Tahoe540. My alternator sits just below my power steering pump as well, but i could see about relocating everything to the layout similar to your OMC. I will check into it.
    Jason, I think 1 have one those brackets it is made by Imco,running one on my ttbbc I will check and send a pic, Power steering ontop and alternater below
    Dec 2017
    Awesome, Let me know what you have. Appreciate it.
    Jason, Found the bracket. Imco price is 147.00, will sell it for 100.00 plus the ride. It is brand new
ID:	1008362   Click image for larger version.
    Dec 2017
    Curious how the alternator is mounted at the bottom?
    Jason ,Haven't finished mounting ,but a piece of 1" wide flat steel runs over to the alternater from the stud on the oil pan
    Dec 2017
    When you get it all mounted can you take pictures. Not sure if this will work for me.
    My manifold goes past the front edge of the head maybe a half inch. Really hard to tell if it would work for me.
    Jason
